By Razziel
#36535
i think you should add the texture path material as in Cinema 4d, because is very difficult to add all texture paths in all projects, I think this is very important to Cinema 4D Users...
By Tyrone Marshall
#36544
Razziel wrote:i think you should add the texture path material as in Cinema 4d, because is very difficult to add all texture paths in all projects, I think this is very important to Cinema 4D Users...
Hello Razziel,
can you be more specific - are you referring to absolute/relative paths?
By bonsak
#37235
As i stated in an other thread, this is a must.
Regards
Bonsak
By Kabe
#37343
Uuuuh, this thread started quite unspecific. This is bad. And there's no vote either. That Cinemaxwell materials need to support relative paths is certainly not the question. This is a bug, full stop.
I'll setup a poll for the handling of the different channels in Maxwell materials.
Kabe
did you tried luxCore?
