By Christine_Cityscape
#360366
Hi, I've rendered a scene from studio, and now I have been asked to animate a few cameras in the scene. Does anyone know of a script or anything I can use to export individual cameras as frames (scenes) from studio so that I can network render them.
Thanks
Christine
#360368
That's what I thought. Had to ask though just in case.
So if I want to render a sequence over a network, and need the frames in a folder to do so, is the only way to save them out one at a time? If I select the camera when I network render I would have to load the scene manually for each frame and then select the next camera? is that right?
But do you have one camera per frame of animation of a moving camera? I don't understand what the animation movement is. Studio is really not the best to handle these situations - with so many Maxwell plugins, taking the Studio route is not the most productive in my opinion.
By eric nixon
#360418
Hi Christine, dont know if its too late to help, but C4D (with a maxwell plugin) can open mxs files - its good to run an optimization filter across all the objects in case the meshes have become individual triangles, because this can happen.
I expect 3dmax (Nicos?) can open mxs files, I'm not sure.
