By designer-made
#360238
New user here.
Getting some nice render results for a newbie, but for some reason adjustments made to various objects uv sets are not being saved with the MXS file. All other scene options appear to be correct, but when the MXS is re-opened the UV sets have defaulted back to the original state when the material was first applied to the object. Any idea what's going on?
Seems like a problem that would get reported quickly if it were a bug, but I did not find anything in a quick forum search.
Any help will be greatly appreciated. I've lost a lot of work twice now (I assumed I somehow accidentally neglected to save the first time), and don't want to make it three times.
Running 2.7.
Cheers,
#360240
Go to File > Preferences > Import Options > Mxs import options and see if the Normalize UVs of objects with real scale applied option is checked. If that's it, your work is not being lost when you save your MXS, it's being overwritten when you open it.
