By inefecto
#358755
Here's a strange bug we had since we use Maxwell 2.7
It seems to be a polygon rendering problem because we tested the surface with a basic Maxwell shader without map.
Any idea ?
Right before releasing the 2.7.20.0, we realized this is not a bug. It's affected by a previous fix in rendering of normals and this is a problem with geometry. So we decided not to revert the correct fix.
