Everything related to SDK.
By Willy121173
#358157
Hello,
I'm using (learning) python to create a scene to render in Maxwell, but for some reason I cannot use the Cvector function.
The line :
Code: Select all
base.origin = Cvector.assign (0.5,0.5,1.0);
gives me the following error :
Code: Select all
TypeError: unbound method Cvector_assign() must be called with Cvector instance as first argument (got float instance instead)
I interpret this error as if Cvector.assign(double,double,double) does not exist, but according to the documentation it should.
Any idea what I'm doing wrong here?
Thanks in advance!
Regards,
Willy
By Brany
#358163
Hello!
"assign" is a Class method (non-static), so you have to call it from the object itself like this:
base.origin.assign(0.5,0.5,1.0);
Another way to do the same, is creating a CVector object with the values you want, setting the base.origin property like this:
base.origin = Cvector(0.5,0.5,1.0);
Both are correct ;)
Hope it helps!
