By pixymboss
#357745
I have some issue with clip map object.
My object is not Mx textured via the shader. In layout only the faces with the clip map applied to the UV map apprears in both Fire and Mx Render. In addition if I have several UV texture clip mapped only the first one apprears on Fire and Mx Render. With native LW the render is fine.
The issue happens with LW instancer, and I had not tested without instancing yet.
Has somebody noticed the same issue?
By pixymboss
#358090
This issue does not occur if you set the lightwave clip mapped object with Maxwell shaders (real maxwell materials)
By pixymboss
#364201
I will send it once at my office.
Best
By pixymboss
#364206
Sorry, but I cannot reproduce the issue I noticed, all works fine so far.
