By mbbga1
#357621
I'm recently updated to v2.7 and have experienced a couple of problems:
1. I'm unable to adjust the sun position/time of day - previously when you clicked the time of day the sun position would move in MS - all it does is stay static and I'm having to fudge the actual time of day to get daylight onto the model, ie. it's currently set to 4am to respond to what is about 1pm,
2. When I use roll angle in the camera settings, the model rotates a preset value approx. 57 degrees tilting it on its side. No matter what value I enter the building ends up on it side,
I can put up with the roll angle not working, but a fix for the daylight time is needed otherwise I have to keep going back and forwards to adjust the time to see what the render looks like......
By JTB
#357626
Too strange... maybe a re-installation is necessary because I can't confirm any of your problems
By mbbga1
#357785
Hi JTB,
I checked in a new file and the problem doesn't occur. The current file did crash after starting a render just after I'd updated to v2.7 so it's likely done something to the file to partially corrupt it? Is there a purge command with MR? Thanks.
