By pixymboss
#357596
I have done some quick tests with the new grass basic settings on a large field (426m x 84m). It is very Ram consuming :(
On a smaller field (22m x 10m), Ram comsuption is quite fair.
By pixymboss
#357601
Yes with LOD on
By pixymboss
#357645
Mihnea Balta wrote:Do you mean during rendering, or in Lightwave?
During fire rendering or Maxwell render rendering. I did not render with lw off course.
By Mihnea Balta
#357648
I was asking about LW because I wanted to make sure the ram isn't taken up by the viewport preview. The render itself can consume a lot of memory for grass because it's a geometric solution so it has to keep data about each blade. Multiply 426 by 84 and then by the density you've used and it will probably be a lot of blades.
By pixymboss
#357649
Thanks for this reply. It is what i though it is (true geometric and not instancing)
By nico_cad
#357987
hi boys, i'm new MWR user...and i've difficoult for apply grass effect in my object.
how can see the grass???
who can explain me the system?
By pixymboss
#358004
It is just a modifier to add to your grass object.
