By wagurto
#35963
Hi guys this is a newbe question.
I have viz plug-in from maxwell and no matter what I do I am unable to display map in maxwell. Maps looks fine in viz but when I start maxwell only the color is display. What am I doing wrong? I saw all your wonderfull images and I just wonder why I can't get a simple checker board to display correctly.
Thanks for your help.
By fuso
#35966
wagurto... I hope that you know that you have to use the maxwell material palette. Then create proper UVW mappings for your objects and
place the texture files in your channels for colour or whatever. If you go to your texture file tab switch the harware texturing display on for the texure
itself rather than the material... it's not supported yet... Good luck!
By wagurto
#35991
Fuso. thank you for the pointers buy i was not aware of that. Is there any tutorail or guide lines on how to map materials? Does maxwell come with textures, maps or images to use? where are they? I know that I was missing something.
thanks
By wagurto
#36067
I have reviewed all maxwell documantation, help files, tutorials, and forums, and there is no single indication of how to apply a simple bitmap image to a material. I have been in many different forums and in none of them I have seen that much indiffernce to a begginers questions, yes of course there is a tons of information on phiscys, photography, lighting an all that stuff but nothing about of how to place a mapping.
Well I think my only chance here is to write to the NL and wait for the busy guys to take care of my sally questions.
thanks anyway.
By wagurto
#36261
Thanks Rayman for your answer, but that exactly what I have been doing, I start with a maxwell materials like maxwell difusse then I load a bit map from the viz library like wood or concrete, I apply it to my object I make sure that the UV mapping coordinates look fine. Although in viz materials preview looks fine to me. when I render with maxwell that I got is only the color of the map. What I am missing? Can somebody tell me?
thanks again
See what's going on
[/img][img=http://img61.echo.cx/img61/2499/26ak.th.jpg]
[/img][img=http://img61.echo.cx/img61/7558/14nz.th.jpg]
By wagurto
#36420
Rayman, thanks again but the simple scene was created fresh in viz and render in maxwell beta. But there must be somthing else because the same thing happen to me in alpha version too. Since I got maxwell I am Unable to display a single map in my scenes. That's why I am complaining about lack of documentation.
What kind of bitmaps are they? Safest format to use with Maxwell at the moment is 24 bit jpg. Convert all your textures to that and try again.
Btw to directly link the pics in the post, after you've uploaded them to imageshack, you get several links. Use the top one they give you, the one that starts with [URL
just copy/paste that into your post, no need to use the img tags because they are already in the link provided to you by imageshack.
By wagurto
#36436
Mihai:
Thanks, I am using the map that comes with ViZ (THE ARCHMAPS).
I not sure that are 24 bit jpg. I know that are jpgs.
By wagurto
#36642
Thanks Rayman, How do post the scene? what format does the scene shall have? is ti MXI? Max? or any other I bet that it's something very simple or stupid but I feel bad that I can't overcome this manor obstacule.
:oops:
By rivoli
#36646
a max's zipped archive would do. doesn't have to be a complex scene, just a stripped version that clearly shows the problem you're having.
post it in max format.
have you tried creating a fresh 24 bit in your image editing software and tried rendering with just that texture in the scene?
By wagurto
#36660
How do I attach a zip file of my max scene to this post. I just lear how to attach images using the the free hosting service. Can I use the same system to attach zip files too?
thanks guys for all your valuable help
Mihai Iliuta wrote: have you tried creating a fresh 24 bit in your image editing software and tried rendering with just that texture in the scene?
doesn't your isp provide you with some webspace? either use that, upload your file, post the link here, or upload it to a file sharing webpage, search google for "file sharing". ex rapidshare
By wagurto
#36664
Could be a ftp site? I will find a file sharing as you recommend
By wagurto
#36764
I finally found how to attach my sample file. It is a very simple max file but I can't get the maps to display correctly. I hope some bosy can find my problem and help me to move on with maxwell.
Here is the link to the file
[/url]http://home.ripway.com/2005-6/332705/
