- Thu May 31, 2012 8:23 pm
#356693
Since installing 6.1.1 I have been unable to use Fire or any of the Maxwell export options (in the plug-in such as export to Studio and export to Maxwell Render). When I do, it is as though nothing is in the model, or as though I opened a new file and tried to render without adding any objects. If I hit Fire, I get the sky but not a single object. The same applies to the other export options using the Maxwell plugin. If I export to studio using the plugin the object list is empty, so it's not that the objects are off in space somewhere or something like that.
However, if I use Sketchup's export option under the File menu, I can export to mxs and it'll save correctly, then I can open it in Studio without any problems.
What gives?
What gives?
- By Mark Bell
