- Tue May 29, 2012 8:05 pm
#356615
Hi All,
I'm afraid I can provide an image or scene until tomorrow as I don't have my laptop with me at the moment but I thought I would post now just in case anyone knew what I am talking about.
Basically I have been trying to render a solid object (Lee Perry-Smith's head imported to max as one solid obj - http://www.ir-ltd.net/infinite-3d-head-scan-released) using a solid sss material, It seems to render all the polygon faces with no smoothing.
This happens when using a displacement map, bump map, or just as it is. It may be worth mentioning that when I last tried there was no reflection 0deg or 90deg (both were set to 0 black), this seems like it may be important as when rendering objects with reflection everything seems to be fine.
Does anyone know about this? this happens with single sss as well, does anyone know more about how sss works? do Maxwell sss materials require surface reflection to render smoothing applied by 3ds max or c4d?
I will post more details tomorrow morning when I have the files,
Thanks!
Jules
Thanks!
Jules
