By mocpop
#352491
Hi guys,
when I add mxm-files in the Modo Shader-Tree and change from the Model-Tab to the Render-Tab, Modo crashes. If I remove the mxm-files, the Render-Tab works again normal. How can I fix that?
Alain
By Marton Day8
#352500
Hello,
Does it happen with all kind of mxm files?
For a temporary workaround try to switch off the "Render in modo" switch (Maxwell plugin window - Material settings).
Márton
By Marton Day8
#352532
I can't freeze it here.
Is it Win or OSX version?
Please try to temporarily remove the main modo config file, sometimes it solves the problem. If it doesn't help, please send me a very simple sample scene.
Thanks,
Márton
