By kami
#352352
Hi
I got a question concerning real scale and blocks:
I've got a rotated table in the scene (13° rotated). The texture on it looks like this:
So I wanted to rotate it. Went into the block edit and rotated the texture with the real scale controls. Not it shows correclty:
also if i type maxwell_restoreviewport inside the blockedit it looks perfectly:
Now, wenn i leave the block edit it stays like this.
But when I use the maxwell_restoreviewport command again it switches back to the wrong view.
Is this something that could be fixed?
Cheers, kami
#352471
Well, the behavior is a bit different here:
  1. make a box, apply a real scale material.
  2. block the box, create some copies of the block.
  3. everything is looking good.
  4. double-click one box to enter Block Edit: the real scale mapping is lost.
  5. Restore Viewport: this fixes the real scale mapping.
  6. change obj properties > Maxwell > Real Scale texture rotations.
  7. everything is working fine.
  8. click OK in the Block Edit box: real scale mapping & rotations are lost.
  9. Restore Viewport: this fixes real scale mapping & rotations.
So it works, with the caveat that you have to use Restore Viewport after entering & exiting Block Edit. For what it's worth, that is not due to anything the plugin is doing -- it is getting changed, and we are then fixing it using Restore Viewport. I swear, I should just remove this feature so that people would have a reason to pressure McNeel to implement it natively, where it belongs.
By kami
#352505
Okay. I've played around with it a little bit.
It does almost work the way you describe, except that I get a wrong mapping when I am inside a rotated block and restore viewport. (point 5 to 7)
So the trick would be, not to trust the view you see inside the block edit then and always leave the block and restore the viewport afterwards.
