- Sun Jan 29, 2012 6:25 am
#352073
If anyone can help.
I noticed that objects within transparent material will render out blur.
Im refering more to the object edges appearing blur (pointed in red arrows). Is there any settings that i can use or set to prevent this? Im rendering them huge, almost 9000 pixels so they are very obvious. The rest (Outside the transparent material) appear alright, in sharpness (with proper DOF set).
Product A: The cap (Transparent material) is very thin so i doubt is the thickness that is affecting. I tried different transparent materials but the inner object rendered out to be same, blur.
Product B: The object (Transparent material) outside is much thicker, if is the thickness that affects it then this will be much blurer that the above object but is not. Again i tried different materials but the inner object rendered out blur as well.
If anyone can help.
Last edited by Tan Boon Meng on Mon Jan 30, 2012 12:46 pm, edited 1 time in total.
- By Matteo Villa
