- Thu Jan 26, 2012 4:46 am
#351958
Hey Guys,
I don't post here often but I'm a constant lurker. Anyways, I usually use Maxwell for Architectural Renderings only but have ventured into some specialty logo design. I am trying to create an aircraft aluminum texture similar to this:
The issue that I am having is that this is a straight on render and this piece will have no curves. I've messed with lighting, environment, etc but still not even close. I have better luck with creating the texture from scratch in photoshop but it lacks the life that the rendered textured could have. Any advice would be appreciated. I'm thinking I might have to create some soft of displacement map for the imperfections in the metal as well as around the depressions the rivets make. I have the rivets as a separate 3D object and they render great.
Thanks!
Al
Thanks!
Al
