#350880
Hi all,
I have been using the modo plugin to render my scenes, but have been solely creating materials within the modo shader tree - i have to say i am totally happy with the results.
Should the correct workflow be:
1. to re-make all my materials with the maxwell material editor.
2. only re-make more complex materials.
3. let the plugin convert as I am currently doing.
I obviously want to get the best from the maxwell renderer, and am curious to what others do with regards to materials.
Best Regards,
Matt.
#350883
Hi Matt,
I am happy automatic material conversion works for you!
If you use mxm materials you have better control over the result and this is good because:
- you can reach better quality
- you can create materials with faster render times (you have more control to optimize the material)
Márton
