- Mon Dec 05, 2011 7:17 pm
#350323
I'm just trying some things with Maxwell ...
For all who aren't confirm with it: a difference between Modo and Maxwell is that Maxwell don't use lights as Modo does.
I set up a location with two large Area-Lights in Modo and exported the scene then to Maxwell to see how this Renderer will interpret this.
My Area-Lights in Modo are shining with 3.0 W/smr2 -> because they are large, the location becomes bright enough. But, the emitters in Maxwell are working on a different way. Saying to them they should shine also with 3.0 W is ... the result is not at all bright like in Modo.
How can I convert/translate the light correctly from Modo to Maxwell?
Anybody out there who knows this?
Thank you,
Alain
Thank you,
Alain
- By Matteo Villa
