#350152
Quick question, in 2.5.15 a feature was added called: Added auto-detection for starting network node & manager. Basically, when you submit a job via network render, the manager and the node auto launch at the same time. The issue I am having is I want to control who is running nodes and there seems to be some confusion when multiple managers are running on a network.
Is there a command line flag I can put in somewhere or some way I can even uninstall the node and manager from client machines (those submitting, but not participating in the rendering process).
Thanks.
#350153
There is no explicit function for doing this, but it is easily accomplished by redefining some plugin methods. Just go to your SketchUp plugins folder and create a file named maxwell.mod.rb. Open the file in Notepad and paste in the following Ruby code:
Code: Select all
require 'maxwell'
module MX
  def MX.is_network_node_running?
    return true
  end
  def MX.is_network_manager_running?
    return true
  end
end
This file will be loaded after the main maxwell.rb file -- what it does is to fool the plugin into thinking that the node and manager are already running.
