By artiscon
#349796
hello,
I have problem to independently adjust multiligts in Max render.When I adjust one light, other change value too.I must be doing something wrong?
It did work before Max update....which I like .
thanks
tony
#349816
It seems to be working correctly here. With Multilight enabled, you should see one slider per emitter material (not per piece of emitter geometry) in Maxwell Render, so do you have more than one emitter material in your scene?
By artiscon
#349849
Thank you for quick reply. I have three emitters,sky,sun,and hdri in this job. In max. render Multilight window is showing them correctly.I can move sliders ok, but once I change slider range on any one (incl sky and sun) that new value
applies to every other light and emitter.Then, I can adjust values by moving slider, but usually, sky has too big value,so I have to reduce range on it, but it reduces range on other emitters too.They somehow don't work independently.I'm using
OS X 10.6.8 i-mac 2.93GHz 16 Gb ram.
thanks,
tony
#349856
I have not been able to reproduce this here, and as I don't think it would be a plugin-specific issue, you may want to create as simple a scene as possible which shows this behavior, and then post about it in the bugs section of the forum.
