By itsallgoode9
#349477
What is the deal with randomly being unable to export geo out of maxwell render with it telling me it's protected?
I created the geo in maya, exported to an mxs (made sure protect geometry was not selected) brought in maxwell to work with, and now need to export as an obj but once again maxwell won't let me. what is the deal with this? for the past 4 or 5 years this issue has popped up numerous times for me as well as others on this forum. What causes maxwell to think geo is protected when it is not?
#349528
it was a new scene....here are the steps below. It doesn't do it with every file, it's just random.
1. Export out of Maya as .mxs (making sure protect geo was turned off)
2. create new scene in maxwell studio
3. import .mxs into studio
4. work with object for a while, setting up materials and lighting
5. try to export object as a .obj
6. projected geo error.
#349566
The problem is, the only time I ever need to export geo is after I've adjusted the angle of something in Maxwell Studio. I'll just need it for positioning reference to model things in maya.
Having said that, it looks like it works fine if i try to export right after I import the object. I have a bottle that I exported from maya and imported into maxwell and setup a scene around and did some test renders. That was about an hour ago and I just now tried to export it an I got the protected geo error. After I read your post, I created a new scene, imported the exact some .mxs (which was exported from maya) and was able to export out of studio as a .obj perfectly fine.
So somehow, within an hour of working with the model it apparently went from exporting fine to being protected.
#349584
The main reason is maya doesn't have render region. I tried working in maya using the plugin but SO much time got wasted by not having render region. Alot of my renders are at 6000px and you just can't work on an image like that without render region. Other than that, overall, I just like working in studio for rendering better than in Maya. Screen layout/UI is obviously more tailored to rendering since that's all it's being used for.
