By gotoxy av-media
#348801
just did a few tests with READ BACK MULTILIGHT:
camera data - correct!
sky & sun data - correct!
but the new SPOT,AREA and POINTLIGHT DATA are not reimported correctly...data seems to be added instead of replaced!
please confirm!
By Mihnea Balta
#348806
There's a problem when the intensity multiplier (Maxwell render rollup) is left at its default (100). If you change that to any other number, the values will be read back correctly. We will fix the issue in the next build.
