By Fernando Tella
#347681
Hi! I'm experiencing something strange when mapping objects in max. I don't know exactly what triggers the bug but it happens quite often.
Sometimes when moving the mapping gizmo the projected texture instead of moving along with the gizmo moves like x1.5 times the distance the gizmo moves. It's a screen problem only because it renders fine, with the texture where it should be, but you have to map blindly because the screen does not match the render.
Using Direct3D, by the way.
Any clue?
Thanks!
Last edited by Fernando Tella on Fri Oct 07, 2011 11:01 pm, edited 1 time in total.
By Miguel Piñón
#352664
Hi Bogdan,
I found a problem too with the UVWmapping in 3dsMax and the mapping in the maxwell render....... The mapping in 3dsmax Tile U under the material editor in the bitmap tiling, produce a different result in maxwell render.
An images explain better than my english :oops:
And the render result........ (the tiling it's different from the 3dsmax tiling in the top dirt effect)
Any comment?
:arrow:
