#347406
hi,
I have been awhile from MR for sometime, and now trying to reorganize workflow in the office for MR using Sketchup. ( been using MR since alpha version! )
We always found the automxm pretty useful in the workflow in the pre 2,0 versions, and the scene manager appearance has basically not improved anything for us ( we produce many images at various steps of developments of the projects, changing geometry often, and studio is not useful for us...). Basically the original philosophy to have a sketch up material name matching that of a mxm counterpart seemed to us the best and user friendly.
Hence our long work of creating many many mxm's to our needs, then when needed in SU, only had to create the SU counterpart with a reduced version of the jpg ( SU way of dealing with materials is a crap...).
Now this has all changed, our workflow has been slow as hell trying to assign the materials in SU again when needed and not having them at once in SU, and comes the first bug:
80% of all our mxm's are greyed out and unelectable, despite there and working in mxed . ( see screen capture).. they were created at the same time of the other ones, with the same versions of mxed but cannot be used...
Then comes the Mxed issues: save as the mxm crashes the interface, making it impossible to test if the scene manager loading issue comes from the files...
Please help !
Nils
ps: looking for feedback also from fellow OSX/SU users regarding the slowness of graphic card compare to shitty PC: the Geforce GT 120 OEM is crap and the macpro is slower manipulating a file than a machine 1/5th of its price ( PCwinXP)..any good card i could upgrade to?
#347407
Now this has all changed, our workflow has been slow as hell trying to assign the materials in SU again when needed and not having them at once in SU.
Are you aware that this plugin also has Auto MXM? See Scene Manager > Output > Export > Auto MXM.
Please go to Scene Manager > Options > User Interface, change the File Browsers option, and let me know if it helps.
I don't understand -- which interface crashes: MXED, the Scene Manager, or SketchUp? Which version of the plugin are you using, which version of Maxwell, and which version of SketchUp?
#347543
JD
Thnx for taking the time to answer
- automxm yes of course...since its the most useful feature...however there is still the UV mapping issue> how to set it good in SU needs to have at least something from the mxm to use in SU...the old school way was to have a small reduced weight jpg of the reflectance map of the mxm and load it as material with same name...but since there is a problem loading the mxm's ( see next point)
- It seems there is a bug in the browser indeed: in default it works but not in the preset " custom" interface.
Last bug is really unknown here is details below:
When save as mxm in the mxed it crashes and sends a bug reports...
Thnx
Nils
Process: Mxed [256]
Path: /Applications/Maxwell 2/Mxed.app/Contents/MacOS/Mxed
Identifier: com.nextlimit.Mxed
Version: ??? (2.5.1)
Code Type: X86-64 (Native)
Parent Process: launchd [124]
Date/Time: 2011-10-03 14:07:57.023 +0200
OS Version: Mac OS X 10.7.1 (11B26)
Report Version: 9
Interval Since Last Report: 245502 sec
Crashes Since Last Report: 7
Per-App Interval Since Last Report: 1326 sec
Per-App Crashes Since Last Report: 4
Anonymous UUID: 268A5384-7AE1-4A67-98DB-708449485A62
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: 0x000000000000000d, 0x0000000000000000
VM Regions Near 0:
__TEXT 0000000100000000-00000001002cf000 [ 2876K] r-x/rwx SM=COW /Applications/Maxwell 2/Mxed.app/Contents/MacOS/Mxed
Application Specific Information:
objc[256]: garbage collection is OFF
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 QtCore 0x00000001004e163c qDeleteInEventHandler(QObject*) + 12
1 QtCore 0x00000001004e277a QObject::event(QEvent*) + 426
2 QtGui 0x00000001006fcd8d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 189
3 QtGui 0x0000000100701464 QApplication::notify(QObject*, QEvent*) + 2036
4 QtCore 0x00000001004d165c QCoreApplication::notifyInternal(QObject*, QEvent*) + 124
5 QtCore 0x00000001004d267d QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 653
6 com.apple.CoreFoundation 0x00007fff8c48e241 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
7 com.apple.CoreFoundation 0x00007fff8c48daad __CFRunLoopDoSources0 + 253
8 com.apple.CoreFoundation 0x00007fff8c4b48d9 __CFRunLoopRun + 905
9 com.apple.CoreFoundation 0x00007fff8c4b4216 CFRunLoopRunSpecific + 230
10 com.apple.HIToolbox 0x00007fff87ead4ff RunCurrentEventLoopInMode + 277
11 com.apple.HIToolbox 0x00007fff87eb4b73 ReceiveNextEventCommon + 181
12 com.apple.HIToolbox 0x00007fff87eb4aae BlockUntilNextEventMatchingListInMode + 62
13 com.apple.AppKit 0x00007fff8c659191 _DPSNextEvent + 659
14 com.apple.AppKit 0x00007fff8c658a95 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
15 com.apple.AppKit 0x00007fff8c90ea4d -[NSApplication _realDoModalLoop:peek:] + 610
16 com.apple.AppKit 0x00007fff8c90e681 -[NSApplication runModalForWindow:] + 120
17 com.apple.AppKit 0x00007fff8cb8ddc9 -[NSSavePanel runModal] + 300
18 com.apple.AppKit 0x00007fff8cb8bd8d -[NSSavePanel runModalForDirectory:file:types:] + 247
19 com.apple.AppKit 0x00007fff8cb8be2e -[NSSavePanel runModalForDirectory:file:] + 21
20 QtGui 0x00000001006e8961 -[QNSOpenSavePanelDelegate runApplicationModalPanel] + 257
21 QtGui 0x00000001006e68b2 QFileDialogPrivate::_q_macRunNativeAppModalPanel() + 82
22 QtGui 0x0000000100b5d786 QFileDialog::qt_metacall(QMetaObject::Call, int, void**) + 1094
23 QtCore 0x00000001004e4cdb QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 603
24 QtCore 0x00000001004ebd77 QSingleShotTimer::timerEvent(QTimerEvent*) + 39
25 QtCore 0x00000001004e277a QObject::event(QEvent*) + 426
26 QtGui 0x00000001006fcd8d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 189
27 QtGui 0x0000000100701464 QApplication::notify(QObject*, QEvent*) + 2036
28 QtCore 0x00000001004d165c QCoreApplication::notifyInternal(QObject*, QEvent*) + 124
29 QtCore 0x00000001004d267d QCoreApplicationPrivate::sendPostedEvents(QObject*, int, QThreadData*) + 653
30 com.apple.CoreFoundation 0x00007fff8c48e241 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
31 com.apple.CoreFoundation 0x00007fff8c48daad __CFRunLoopDoSources0 + 253
32 com.apple.CoreFoundation 0x00007fff8c4b48d9 __CFRunLoopRun + 905
33 com.apple.CoreFoundation 0x00007fff8c4b4216 CFRunLoopRunSpecific + 230
34 com.apple.HIToolbox 0x00007fff87ead4ff RunCurrentEventLoopInMode + 277
35 com.apple.HIToolbox 0x00007fff87eb4b73 ReceiveNextEventCommon + 181
36 com.apple.HIToolbox 0x00007fff87eb4aae BlockUntilNextEventMatchingListInMode + 62
37 com.apple.AppKit 0x00007fff8c659191 _DPSNextEvent + 659
38 com.apple.AppKit 0x00007fff8c658a95 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 135
39 com.apple.AppKit 0x00007fff8c6553d6 -[NSApplication run] + 463
40 QtGui 0x00000001006bc865 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1493
41 QtCore 0x00000001004d0774 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
42 QtCore 0x00000001004d0a84 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 180
43 QtGui 0x0000000100b498f5 QDialog::exec() + 229
44 QtGui 0x0000000100b5ba2d QFileDialog::getSaveFileName(QWidget*, QString const&, QString const&, QString const&, QString*, QFlags<QFileDialog::Option>) + 365
45 com.nextlimit.Mxed 0x0000000100036216 0x100000000 + 221718
46 com.nextlimit.Mxed 0x000000010009f3e4 0x100000000 + 652260
47 QtCore 0x00000001004e4cdb QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 603
48 QtGui 0x00000001006f70e1 QAction::triggered(bool) + 49
49 QtGui 0x00000001006f8484 QAction::activate(QAction::ActionEvent) + 180
50 QtGui 0x0000000100ad68a0 QMenuPrivate::activateCausedStack(QList<QPointer<QWidget> > const&, QAction*, QAction::ActionEvent, bool) + 352
51 QtGui 0x0000000100adc594 QMenuPrivate::activateAction(QAction*, QAction::ActionEvent, bool) + 324
52 QtGui 0x0000000100753d80 QWidget::event(QEvent*) + 2384
53 QtGui 0x0000000100adbfcb QMenu::event(QEvent*) + 107
54 QtGui 0x00000001006fcd8d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 189
55 QtGui 0x00000001007015e0 QApplication::notify(QObject*, QEvent*) + 2416
56 QtCore 0x00000001004d165c QCoreApplication::notifyInternal(QObject*, QEvent*) + 124
57 QtGui 0x00000001006fd07c qt_sendSpontaneousEvent(QObject*, QEvent*) + 44
58 QtGui 0x00000001006b7320 qt_mac_handleMouseEvent(void*, void*, QEvent::Type, Qt::MouseButton) + 1328
59 QtGui 0x00000001006a8e2f -[QCocoaPanel sendEvent:] + 559
60 com.apple.AppKit 0x00007fff8c6bef19 -[NSApplication sendEvent:] + 5665
61 com.apple.AppKit 0x00007fff8c65542b -[NSApplication run] + 548
62 QtGui 0x00000001006bc865 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1493
63 QtCore 0x00000001004d0774 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
64 QtCore 0x00000001004d0a84 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 180
65 QtGui 0x0000000100ad9974 QMenu::exec(QPoint const&, QAction*) + 116
66 QtGui 0x0000000100ae7ec9 QPushButtonPrivate::_q_popupPressed() + 153
67 QtGui 0x0000000100ae8712 QPushButton::qt_metacall(QMetaObject::Call, int, void**) + 226
68 QtCore 0x00000001004e4cdb QMetaObject::activate(QObject*, QMetaObject const*, int, void**) + 603
69 QtGui 0x0000000100a53603 QAbstractButtonPrivate::emitPressed() + 51
70 QtGui 0x0000000100a537cb QAbstractButton::mousePressEvent(QMouseEvent*) + 123
71 QtGui 0x0000000100754034 QWidget::event(QEvent*) + 3076
72 QtGui 0x0000000100a53b58 QAbstractButton::event(QEvent*) + 40
73 QtGui 0x0000000100ae8535 QPushButton::event(QEvent*) + 69
74 QtGui 0x00000001006fcd8d QApplicationPrivate::notify_helper(QObject*, QEvent*) + 189
75 QtGui 0x00000001007015e0 QApplication::notify(QObject*, QEvent*) + 2416
76 QtCore 0x00000001004d165c QCoreApplication::notifyInternal(QObject*, QEvent*) + 124
77 QtGui 0x00000001006fd07c qt_sendSpontaneousEvent(QObject*, QEvent*) + 44
78 QtGui 0x00000001006b7320 qt_mac_handleMouseEvent(void*, void*, QEvent::Type, Qt::MouseButton) + 1328
79 com.apple.AppKit 0x00007fff8c72666e -[NSWindow sendEvent:] + 6280
80 QtGui 0x00000001006b0c8e -[QCocoaWindow sendEvent:] + 206
81 com.apple.AppKit 0x00007fff8c6bef19 -[NSApplication sendEvent:] + 5665
82 com.apple.AppKit 0x00007fff8c65542b -[NSApplication run] + 548
83 QtGui 0x00000001006bc865 QEventDispatcherMac::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 1493
84 QtCore 0x00000001004d0774 QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 68
85 QtCore 0x00000001004d0a84 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 180
86 QtCore 0x00000001004d297c QCoreApplication::exec() + 188
87 com.nextlimit.Mxed 0x000000010009bd3f 0x100000000 + 638271
88 com.nextlimit.Mxed 0x0000000100004840 0x100000000 + 18496
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff83a647e6 kevent + 10
1 libdispatch.dylib 0x00007fff82d8f60e _dispatch_mgr_invoke + 923
2 libdispatch.dylib 0x00007fff82d8e19e _dispatch_mgr_thread + 54
Thread 2:
0 libsystem_kernel.dylib 0x00007fff83a64192 __workq_kernreturn + 10
1 libsystem_c.dylib 0x00007fff88d48594 _pthread_wqthread + 758
2 libsystem_c.dylib 0x00007fff88d49b85 start_wqthread + 13
Thread 3:
0 libsystem_kernel.dylib 0x00007fff83a63bca __psynch_cvwait + 10
1 libsystem_c.dylib 0x00007fff88d4a274 _pthread_cond_wait + 840
2 QtCore 0x00000001003d7a30 QWaitCondition::wait(QMutex*, unsigned long) + 304
3 QtGui 0x0000000100b847f3 QFileInfoGatherer::run() + 547
4 QtCore 0x00000001003d6c65 QThreadPrivate::start(void*) + 165
5 libsystem_c.dylib 0x00007fff88d468bf _pthread_start + 335
6 libsystem_c.dylib 0x00007fff88d49b75 thread_start + 13
Thread 4:
1 QtCore 0x00000001004b58b8 QKqueueFileSystemWatcherEngine::run() + 152
2 QtCore 0x00000001003d6c65 QThreadPrivate::start(void*) + 165
3 libsystem_c.dylib 0x00007fff88d468bf _pthread_start + 335
4 libsystem_c.dylib 0x00007fff88d49b75 thread_start + 13
Thread 5:
Thread 6:
Thread 7:
Thread 8:
Thread 9:
Thread 10:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff83a63df2 __select + 10
1 com.apple.CoreFoundation 0x00007fff8c4fd66b __CFSocketManager + 1355
2 libsystem_c.dylib 0x00007fff88d468bf _pthread_start + 335
3 libsystem_c.dylib 0x00007fff88d49b75 thread_start + 13
Thread 11:
Thread 12:: com.apple.appkit-heartbeat
0 libsystem_kernel.dylib 0x00007fff83a63e42 __semwait_signal + 10
1 libsystem_c.dylib 0x00007fff88cfcdea nanosleep + 164
2 libsystem_c.dylib 0x00007fff88cfcbb5 usleep + 53
3 com.apple.AppKit 0x00007fff8c88f0b8 -[NSUIHeartBeat _heartBeatThread:] + 1727
4 com.apple.Foundation 0x00007fff8722b1ea -[NSThread main] + 68
5 com.apple.Foundation 0x00007fff8722b162 __NSThread__main__ + 1575
6 libsystem_c.dylib 0x00007fff88d468bf _pthread_start + 335
7 libsystem_c.dylib 0x00007fff88d49b75 thread_start + 13
Thread 13:
1 libsystem_c.dylib 0x00007fff88d4a2a6 _pthread_cond_wait + 890
2 com.apple.FinderKit 0x00007fff858663c3 TConditionVariable::WaitWithTimeout(TMutex&, unsigned long long, bool&) + 69
3 com.apple.FinderKit 0x00007fff858913c6 TThreadSafeQueue<TThumbnailExtractorThread::TThumbnailQueueData>::WaitForChange(unsigned long long) + 40
4 com.apple.FinderKit 0x00007fff85890756 TThumbnailExtractorThread::Main() + 302
5 com.apple.FinderKit 0x00007fff85866675 TThread::MainGlue(void*) + 29
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0xf000000010335c65 rbx: 0x0000000107c52c60 rcx: 0x0000000103316e34 rdx: 0x0000000100614ca0
rdi: 0x000000010dc5a140 rsi: 0x00007fff5fbf98c0 rbp: 0x00007fff5fbf9940 rsp: 0x00007fff5fbf9940
r8: 0x0000000000000006 r9: 0x0000000107a94730 r10: 0x00000000a942489e r11: 0x000000006441a3cf
r12: 0x000000010dc5a140 r13: 0x0000000107c52c60 r14: 0x000000010142c310 r15: 0x0000000107c52c60
rip: 0x00000001004e163c rfl: 0x0000000000010202 cr2: 0x00000001071fb000
Logical CPU: 4
Binary Images:
0x100000000 - 0x1002cefe7 +com.nextlimit.Mxed (??? - 2.5.1) <B2A11E94-E728-7065-D6E0-6B10C19F7E85> /Applications/Maxwell 2/Mxed.app/Contents/MacOS/Mxed
0x1003b8000 - 0x100613fef +QtCore (4.6.3 - compatibility 4.6.0) <DDE1C629-81F5-468D-F7D3-6CE4A270F6FB> /Applications/Maxwell 2/*/QtCore.framework/Versions/4/QtCore
0x100685000 - 0x100fe6fe7 +QtGui (4.6.3 - compatibility 4.6.0) <7AC00DBE-F94A-D8B3-AA01-DA98A94FBE03> /Applications/Maxwell 2/*/QtGui.framework/Versions/4/QtGui
0x1011f2000 - 0x10130bfff +QtNetwork (4.6.3 - compatibility 4.6.0) <C6E40C55-92FE-2B0C-8E04-C10F6FF4990E> /Applications/Maxwell 2/*/QtNetwork.framework/Versions/4/QtNetwork
0x103654000 - 0x10365afff com.apple.URLMount.CIFSPlugin (5.0.0 - 5.0.0) <74D86729-EF6D-3165-8CBE-347561C11585> /System/Library/Filesystems/NetFSPlugins/smb.bundle/Contents/MacOS/smb
0x10366a000 - 0x10366dfff libLatinSuppConverter.dylib (54.0.0 - compatibility 1.0.0) <7E087B67-5698-34B6-9F16-1E0C1C3FF0DD> /System/Library/CoreServices/Encodings/libLatinSuppConverter.dylib
0x103677000 - 0x10367dfef libcldcpuengine.dylib (1.50.61 - compatibility 1.0.0) <EAC03E33-595E-3829-8199-479FA5CD9987> /System/Library/Frameworks/OpenCL.framework/Libraries/libcldcpuengine.dylib
0x1037ed000 - 0x1037f0ff7 libCoreFSCache.dylib (??? - ???) <783C2402-CA3F-3D9B-B909-0F251145CF1D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
0x1037f4000 - 0x1037f4ffd +cl_kernels (??? - ???) <28E311D8-1412-43B7-8BF1-B929F7C6CB38> cl_kernels
0x1037f9000 - 0x1037faff3 +cl_kernels (??? - ???) <81A188BF-6F4D-4A49-B91C-9BF38BE3D905> cl_kernels
0x1058ed000 - 0x1058eeffc +cl_kernels (??? - ???) <412003A3-8E46-46C5-9011-C119F3C50F08> cl_kernels
0x105df1000 - 0x105df2ff3 +cl_kernels (??? - ???) <76584E08-A94A-49A9-B10F-F2C3F6481CC4> cl_kernels
0x105ffd000 - 0x105ffdff5 +cl_kernels (??? - ???) <424428E7-ED43-4E5F-B55F-E4229B08A420> cl_kernels
0x1078d8000 - 0x1078f1fff com.apple.SMBClient (1.7 - 1.7) <1EBFC04F-3525-30DE-9A8F-D01BC208F67B> /System/Library/PrivateFrameworks/SMBClient.framework/Versions/A/SMBClient
0x10fb00000 - 0x10fb7efff com.apple.DCERPC (1.0 - 46) <D2693B9A-1939-32A0-8BBE-F4CFB02A2FCB> /System/Library/PrivateFrameworks/DCERPC.framework/Versions/A/DCERPC
0x10fd40000 - 0x10fdd3ff7 unorm8_bgra.dylib (1.50.61 - compatibility 1.0.0) <3ED8B0D5-4A55-3E39-8490-B7BC1780F67B> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_bgra.dylib
0x10ff00000 - 0x10ff93ff7 unorm8_argb.dylib (1.50.61 - compatibility 1.0.0) <D453434E-9E63-3D38-B59E-6B333A5373D6> /System/Library/Frameworks/OpenCL.framework/Libraries/ImageFormats/unorm8_argb.dylib
0x7fff6030a000 - 0x7fff6033eac7 dyld (195.5 - ???) <4A6E2B28-C7A2-3528-ADB7-4076B9836041> /usr/lib/dyld
0x7fff80e23000 - 0x7fff80e35ff7 libsasl2.2.dylib (3.15.0 - compatibility 3.0.0) <6245B497-784B-355C-98EF-2DC6B45BF05C> /usr/lib/libsasl2.2.dylib
0x7fff80e4f000 - 0x7fff815e3fff com.apple.CoreAUC (6.11.03 - 6.11.03) <5A56B2DC-A0A6-357B-ADF2-5714AFEBD926> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
0x7fff816eb000 - 0x7fff816f2fff com.apple.NetFS (4.0 - 4.0) <B9F41443-679A-31AD-B0EB-36557DAF782B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x7fff816f3000 - 0x7fff816f4fff liblangid.dylib (??? - ???) <CACBE3C3-2F7B-3EED-B50E-EDB73F473B77> /usr/lib/liblangid.dylib
0x7fff816f5000 - 0x7fff8171bff7 com.apple.framework.familycontrols (3.0 - 300) <72FEA71A-5865-3875-97E9-3C8C96B7F7FA> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x7fff8171c000 - 0x7fff81778ff7 com.apple.QuickLookFramework (3.0 - 489.1) <26470DFE-B3D7-3E05-A4D7-98B64FCB230B> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x7fff81779000 - 0x7fff8177dff7 com.apple.CommonPanels (1.2.5 - 94) <0BB2C436-C9D5-380B-86B5-E355A7711259> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff8177e000 - 0x7fff81786fff libsystem_dnssd.dylib (??? - ???) <7749128E-D0C5-3832-861C-BC9913F774FA> /usr/lib/system/libsystem_dnssd.dylib
0x7fff81787000 - 0x7fff817c2fff com.apple.LDAPFramework (3.0 - 120.1) <0C23534F-A8E7-3144-B2B2-50F9875101E2> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff81854000 - 0x7fff818b4fff libvDSP.dylib (325.3.0 - compatibility 1.0.0) <74B62E70-4189-3022-8FC9-1182EA7C6E34> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x7fff818fb000 - 0x7fff81965fff com.apple.framework.IOKit (2.0 - ???) <F79E7690-EF97-3D04-BA22-177E256803AF> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff81a46000 - 0x7fff81a48ff7 com.apple.print.framework.Print (7.0 - 247) <579D7E49-A7F4-3C41-9434-3114B8A9B96C> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff81a49000 - 0x7fff81a4cfff libRadiance.dylib (??? - ???) <DCDA308D-4856-3631-B6D7-7A8B94169BC0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x7fff81a4d000 - 0x7fff81a53fff com.apple.DiskArbitration (2.4 - 2.4) <5185FEA6-92CA-3CAA-8442-BD71DBC64AFD> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff81a54000 - 0x7fff81a55fff libsystem_sandbox.dylib (??? - ???) <8D14139B-B671-35F4-9E5A-023B4C523C38> /usr/lib/system/libsystem_sandbox.dylib
0x7fff81a56000 - 0x7fff81a65fff com.apple.opengl (1.7.4 - 1.7.4) <38AF4430-7E81-3C98-9330-21DCDA90507E> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff81a66000 - 0x7fff81a69fff com.apple.AppleSystemInfo (1.0 - 1) <598ADC13-C994-3579-A885-0D6658DDD564> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
0x7fff81b5d000 - 0x7fff81b68ff7 com.apple.speech.recognition.framework (4.0.19 - 4.0.19) <7ADAAF5B-1D78-32F2-9FFF-D2E3FBB41C2B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff81cac000 - 0x7fff81cebfff com.apple.AE (527.6 - 527.6) <6F8DF9EF-3250-3B7F-8841-FCAD8E323954> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x7fff81cec000 - 0x7fff81cf9fff com.apple.KerberosHelper (3.0 - 1.0) <040790B0-527E-337B-8E0D-CC4B4B36634B> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
0x7fff81cfa000 - 0x7fff81d22ff7 com.apple.CoreVideo (1.7 - 70.0) <59D5B407-CCB6-3406-8C55-C1B0168D7DC2> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff81d28000 - 0x7fff81d2cfff libmathCommon.A.dylib (2026.0.0 - compatibility 1.0.0) <FF83AFF7-42B2-306E-90AF-D539C51A4542> /usr/lib/system/libmathCommon.A.dylib
0x7fff81d2f000 - 0x7fff81d7dff7 libauto.dylib (??? - ???) <F0004B88-CA01-37D0-A77F-6651C4EC7D8E> /usr/lib/libauto.dylib
0x7fff81d7e000 - 0x7fff81d95fff com.apple.CFOpenDirectory (10.7 - 144) <9709423E-8484-3B26-AAE8-EF58D1B8FB3F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff81da4000 - 0x7fff81dbbfff com.apple.MultitouchSupport.framework (220.62 - 220.62) <7EF58A7E-CB97-335F-A025-4A0F00AEF896> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff81dbc000 - 0x7fff81df6fff com.apple.DebugSymbols (2.1 - 85) <AEF473A5-25BF-3FB7-9A07-320D9CB85959> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff81df7000 - 0x7fff82224fff libLAPACK.dylib (??? - ???) <4F2E1055-2207-340B-BB45-E4F16171EE0D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff82225000 - 0x7fff82225fff com.apple.Accelerate.vecLib (3.7 - vecLib 3.7) <4CC14F7C-BCA7-3CAC-BEC9-B06576E5A15B> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8222e000 - 0x7fff82505fff com.apple.security (7.0 - 55010) <2418B583-D3BD-3BC5-8B07-8289C8A5B43B> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff82514000 - 0x7fff8252afff libGL.dylib (??? - ???) <22064411-0A62-373C-828B-0AA2BA2A8D34> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff8252b000 - 0x7fff826cafff com.apple.QuartzCore (1.7 - 269.0) <E0AFC745-4AC5-36E3-9827-E5344721071D> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff826d1000 - 0x7fff82713ff7 libcommonCrypto.dylib (55010.0.0 - compatibility 1.0.0) <A5B9778E-11C3-3F61-B740-1F2114E967FB> /usr/lib/system/libcommonCrypto.dylib
0x7fff82714000 - 0x7fff82819ff7 libFontParser.dylib (??? - ???) <22AADE96-E54D-3918-9DFA-1967F8B21E54> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8281a000 - 0x7fff82840fff com.apple.framework.internetaccounts (1.0 - 1) <64CC50BB-9EE4-36D1-969A-FDD2210026DC> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
0x7fff82841000 - 0x7fff8286afff libJPEG.dylib (??? - ???) <3DBFEB41-4BF2-3502-872A-BB3738EE61B0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff8286b000 - 0x7fff828e0ff7 libc++.1.dylib (19.0.0 - compatibility 1.0.0) <C0EFFF1B-0FEB-3F99-BE54-506B35B555A9> /usr/lib/libc++.1.dylib
0x7fff82955000 - 0x7fff82959fff libCGXType.A.dylib (600.0.0 - compatibility 64.0.0) <5EEAD17D-006C-3855-8093-C7A4A97EE0D0> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff8295a000 - 0x7fff82a6ffff com.apple.DesktopServices (1.6.0 - 1.6.0) <208D40FC-8BBE-330F-B999-18771BEA6895> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff82a70000 - 0x7fff82a7bfff com.apple.CommonAuth (2.1 - 2.0) <49949286-61FB-3A7F-BF49-0EBA45E2664E> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff82a7c000 - 0x7fff82b88fef libcrypto.0.9.8.dylib (0.9.8 - compatibility 0.9.8) <3AD29F8D-E3BC-3F49-A438-2C8AAB71DC99> /usr/lib/libcrypto.0.9.8.dylib
0x7fff82b89000 - 0x7fff82d8bfff libicucore.A.dylib (46.1.0 - compatibility 1.0.0) <82DCB94B-3819-3CC3-BC16-2AACA7F64F8A> /usr/lib/libicucore.A.dylib
0x7fff82d8c000 - 0x7fff82d9afff libdispatch.dylib (187.5.0 - compatibility 1.0.0) <698F8EFB-7075-3111-94E3-891156C88172> /usr/lib/system/libdispatch.dylib
0x7fff82e1b000 - 0x7fff82e1efff com.apple.help (1.3.2 - 42) <AB67588E-7227-3993-927F-C9E6DAC507FD> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff82e1f000 - 0x7fff82e31ff7 libz.1.dylib (1.2.5 - compatibility 1.0.0) <30CBEF15-4978-3DED-8629-7109880A19D4> /usr/lib/libz.1.dylib
0x7fff82e87000 - 0x7fff82e87fff com.apple.Cocoa (6.6 - ???) <021D4214-9C23-3CD8-AFB2-F331697A4508> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x7fff82e9a000 - 0x7fff82ea8ff7 libkxld.dylib (??? - ???) <65BE345D-6618-3D1A-9E2B-255E629646AA> /usr/lib/system/libkxld.dylib
0x7fff82ea9000 - 0x7fff83350ff7 FaceCoreLight (1.4.2 - compatibility 1.0.0) <6F89E9A9-DEB6-32B5-8B50-3B97F5DB597D> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
0x7fff83351000 - 0x7fff833ccff7 com.apple.print.framework.PrintCore (7.0 - 366) <E663DF78-6729-332D-B763-ABB63A6BBB55> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x7fff833cd000 - 0x7fff833cffff com.apple.TrustEvaluationAgent (2.0 - 1) <80AFB5D8-5CC4-3A38-83B9-A7DF5820031A> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff833d0000 - 0x7fff834aeff7 com.apple.ImageIO.framework (3.1.0 - 3.1.0) <70228E69-063C-32FF-BBE7-FCCD9C5C0864> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff834af000 - 0x7fff83551ff7 com.apple.securityfoundation (5.0 - 55005) <0D59908C-A61B-389E-AF37-741ACBBA6A94> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff83552000 - 0x7fff83553ff7 libsystem_blocks.dylib (53.0.0 - compatibility 1.0.0) <8BCA214A-8992-34B2-A8B9-B74DEACA1869> /usr/lib/system/libsystem_blocks.dylib
0x7fff83554000 - 0x7fff83557ff7 com.apple.securityhi (4.0 - 1) <B37B8946-BBD4-36C1-ABC6-18EDBC573F03> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff83558000 - 0x7fff83587fff com.apple.DictionaryServices (1.2 - 158) <2CE51CD1-EE3D-3618-9507-E39A09C9BB8D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff835b4000 - 0x7fff839cfff7 com.apple.RawCamera.bundle (3.7.2 - 573) <FF8D349E-E8DF-3D12-91E9-BA00C13D5359> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff839d0000 - 0x7fff83a05fff com.apple.securityinterface (5.0 - 55004) <790DDF7E-6BA9-36DD-B818-2322A712E1F5> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x7fff83a06000 - 0x7fff83a07fff libDiagnosticMessagesClient.dylib (??? - ???) <3DCF577B-F126-302B-BCE2-4DB9A95B8598> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff83a4d000 - 0x7fff83a6dfff libsystem_kernel.dylib (1699.22.73 - compatibility 1.0.0) <69F2F501-72D8-3B3B-8357-F4418B3E1348> /usr/lib/system/libsystem_kernel.dylib
0x7fff83a7b000 - 0x7fff83acfff7 com.apple.ImageCaptureCore (3.0 - 3.0) <C829E6A3-3EB6-3E1C-B9B8-759F56E34D3A> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
0x7fff83ad0000 - 0x7fff83aedff7 com.apple.openscripting (1.3.3 - ???) <A64205E6-D3C5-3E12-B1A0-72243151AF7D> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff83aee000 - 0x7fff83f20fe7 com.apple.VideoToolbox (1.0 - 705.35) <B1B9F159-EEE2-38BB-A55E-CDB335A7A226> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x7fff83f21000 - 0x7fff83f78fff libTIFF.dylib (??? - ???) <9E32B490-4C5B-3D96-AF27-9C085C606403> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x7fff83f79000 - 0x7fff83f7afff libunc.dylib (24.0.0 - compatibility 1.0.0) <C67B3B14-866C-314F-87FF-8025BEC2CAAC> /usr/lib/system/libunc.dylib
0x7fff83f7b000 - 0x7fff84294ff7 com.apple.AddressBook.framework (6.0 - 1043) <A6302279-FD1B-3BB7-8419-362425FC5568> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
0x7fff84295000 - 0x7fff842aafff com.apple.FileSync.framework (6.0 - 432) <7DF40003-7A8A-3C42-AC26-FCA0A0DFEE17> /System/Library/PrivateFrameworks/FileSync.framework/Versions/A/FileSync
0x7fff842ab000 - 0x7fff8432dfff com.apple.Metadata (10.7.0 - 627.9) <F293A9A7-9790-3629-BE81-D19C158C5EA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x7fff8432e000 - 0x7fff8432efff com.apple.audio.units.AudioUnit (1.7 - 1.7) <D75971EE-0D74-365A-8E52-46558EA49E87> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff8432f000 - 0x7fff84338fff libnotify.dylib (80.0.0 - compatibility 1.0.0) <BD08553D-8088-38A8-8007-CF5C0B8F0404> /usr/lib/system/libnotify.dylib
0x7fff84339000 - 0x7fff84492ff7 com.apple.audio.toolbox.AudioToolbox (1.7 - 1.7) <296F10D0-A871-39C1-B8B2-9200AB12B5AF> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff84493000 - 0x7fff844b7ff7 com.apple.Kerberos (1.0 - 1) <2FF2569B-F59A-371E-AF33-66297F512CB3> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff844b8000 - 0x7fff844d2fff com.apple.CoreMediaAuthoring (2.0 - 889) <99D8E4C6-DDD3-3B0C-BBFB-A513877F10F6> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthoring
0x7fff844d3000 - 0x7fff844d5fff libCVMSPluginSupport.dylib (??? - ???) <2D21E6BE-CB20-3F76-8DCC-1CB0660A8A5B> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff844e2000 - 0x7fff844e2fff com.apple.ApplicationServices (41 - 41) <03F3FA8F-8D2A-3AB6-A8E3-40B001116339> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff84554000 - 0x7fff845c7fff libstdc++.6.dylib (52.0.0 - compatibility 7.0.0) <6BDD43E4-A4B1-379E-9ED5-8C713653DFF2> /usr/lib/libstdc++.6.dylib
0x7fff845c8000 - 0x7fff846acdef libobjc.A.dylib (228.0.0 - compatibility 1.0.0) <C5F2392D-B481-3A9D-91BE-3D039FFF4DEC> /usr/lib/libobjc.A.dylib
0x7fff846ad000 - 0x7fff846adfff libkeymgr.dylib (23.0.0 - compatibility 1.0.0) <61EFED6A-A407-301E-B454-CD18314F0075> /usr/lib/system/libkeymgr.dylib
0x7fff846ae000 - 0x7fff846b4fff IOSurface (??? - ???) <06FA3FDD-E6D5-391F-B60D-E98B169DAB1B> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff846b5000 - 0x7fff846bcfff libcopyfile.dylib (85.1.0 - compatibility 1.0.0) <172B1985-F24A-34E9-8D8B-A2403C9A0399> /usr/lib/system/libcopyfile.dylib
0x7fff846bd000 - 0x7fff846c2fff libcompiler_rt.dylib (6.0.0 - compatibility 1.0.0) <98ECD5F6-E85C-32A5-98CD-8911230CB66A> /usr/lib/system/libcompiler_rt.dylib
0x7fff846c3000 - 0x7fff846cffff com.apple.DirectoryService.Framework (10.7 - 144) <067ACB41-E9B7-3177-9EDE-C188D9B352DC> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x7fff846d0000 - 0x7fff847b7fff com.apple.backup.framework (1.3 - 1.3) <C7F0B3B6-EAC1-3445-A705-E9F18A45D01D> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff847b8000 - 0x7fff847d5ff7 libxpc.dylib (77.16.0 - compatibility 1.0.0) <0A4B4775-29A9-30D6-956B-3BE1DBF98090> /usr/lib/system/libxpc.dylib
0x7fff849f7000 - 0x7fff84a02ff7 libc++abi.dylib (14.0.0 - compatibility 1.0.0) <8FF3D766-D678-36F6-84AC-423C878E6D14> /usr/lib/libc++abi.dylib
0x7fff84a03000 - 0x7fff84a56fff libFontRegistry.dylib (??? - ???) <8FE14D77-1286-3619-A02E-0AC1A622596E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff84a57000 - 0x7fff84b1eff7 ColorSyncDeprecated.dylib (4.6.0 - compatibility 1.0.0) <E05006B6-A597-3924-851A-FBEC493B598B> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/Versions/A/Resources/ColorSyncDeprecated.dylib
0x7fff84b1f000 - 0x7fff84b29ff7 liblaunch.dylib (392.18.0 - compatibility 1.0.0) <39EF04F2-7F0C-3435-B785-BF283727FFBD> /usr/lib/system/liblaunch.dylib
0x7fff84b8a000 - 0x7fff84ea3fff com.apple.CoreServices.CarbonCore (960.13 - 960.13) <398ABDD7-BB95-3C05-96D2-B54243FC4745> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x7fff84ea4000 - 0x7fff84ee2fff com.apple.bom (11.0 - 183) <841FA160-A37A-368D-B14E-27AA9DD1AEDA> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
0x7fff84ee3000 - 0x7fff84ef5ff7 libbsm.0.dylib (??? - ???) <349BB16F-75FA-363F-8D98-7A9C3FA90A0D> /usr/lib/libbsm.0.dylib
0x7fff84ef6000 - 0x7fff84f32fff libsystem_info.dylib (??? - ???) <BC49C624-1DAB-3A37-890F-6EFD46538424> /usr/lib/system/libsystem_info.dylib
0x7fff84f33000 - 0x7fff84fa9fff com.apple.ISSupport (1.9.8 - 56) <2CEE7E6B-D841-36D8-BC9F-081B33F6E501> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
0x7fff84fe5000 - 0x7fff8500eff7 com.apple.framework.Apple80211 (7.0 - 700.57) <0D7D7E08-377B-32F0-AD91-673F992B5CFF> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff85061000 - 0x7fff85061fff com.apple.Accelerate (1.7 - Accelerate 1.7) <3E4582EB-CFEF-34EA-9DA8-8421F1C3C77D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff85062000 - 0x7fff8508dfff libpcre.0.dylib (1.1.0 - compatibility 1.0.0) <7D3CDB0A-840F-3856-8F84-B4A50E66431B> /usr/lib/libpcre.0.dylib
0x7fff8508e000 - 0x7fff850b5fff com.apple.PerformanceAnalysis (1.10 - 10) <2A058167-292E-3C3A-B1F8-49813336E068> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff850b6000 - 0x7fff851c3fff libJP2.dylib (??? - ???) <D8257CEE-A1C3-394A-8193-6DB7C29A15A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff85306000 - 0x7fff8530bfff libGIF.dylib (??? - ???) <21851808-BFD2-3141-8354-A419479726BF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff8530c000 - 0x7fff85328ff7 com.apple.GenerationalStorage (1.0 - 124) <C0290CA0-A2A0-3280-9442-9D783883D638> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff85697000 - 0x7fff856cafff com.apple.GSS (2.1 - 2.0) <A150154E-40D3-345B-A92D-3A023A55AC52> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
0x7fff856cb000 - 0x7fff856eeff7 com.apple.RemoteViewServices (1.0 - 1) <EB549657-8EDC-312A-B8BE-DEC3E160AC3D> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff856ef000 - 0x7fff8578efff com.apple.LaunchServices (480.19 - 480.19) <41ED4C8B-C74B-34EA-A9BF-34DBA5F52307> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8579a000 - 0x7fff85ae7ff7 com.apple.FinderKit (1.0 - 1) <906BCBF7-CBE6-36D2-A183-4980E73CA5EF> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
0x7fff86989000 - 0x7fff86ac2fef com.apple.vImage (5.0 - 5.0) <C45D2CBE-FA15-3D13-9E9D-A3BF57B84BBE> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff86ac3000 - 0x7fff86b17ff7 com.apple.ScalableUserInterface (1.0 - 1) <1873D7BE-2272-31A1-8F85-F70C4D706B3B> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterface.framework/Versions/A/ScalableUserInterface
0x7fff86b18000 - 0x7fff86b23fff com.apple.DisplayServicesFW (2.5.0 - 302.1.2) <36377733-C737-3F36-A601-85D6188A2AAA> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x7fff86bd7000 - 0x7fff86bddfff libmacho.dylib (800.0.0 - compatibility 1.0.0) <D86F63EC-D2BD-32E0-8955-08B5EAFAD2CC> /usr/lib/system/libmacho.dylib
0x7fff86bde000 - 0x7fff86c07fff com.apple.CoreServicesInternal (113.7 - 113.7) <ACAC98CD-5941-39DB-951A-2509DCCD22FD> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff86c08000 - 0x7fff86c53fff com.apple.SystemConfiguration (1.11 - 1.11) <0B02FEC4-C36E-32CB-8004-2214B6793AE8> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff86c54000 - 0x7fff86c81fe7 libSystem.B.dylib (159.0.0 - compatibility 1.0.0) <7B4D685D-939C-3ABE-8780-77A1889E0DE9> /usr/lib/libSystem.B.dylib
0x7fff86cff000 - 0x7fff870c5fff com.apple.MediaToolbox (1.0 - 705.35) <EC6755D1-58BC-36F5-AB66-143D03A0AF8C> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0x7fff87136000 - 0x7fff871d0ff7 com.apple.SearchKit (1.4.0 - 1.4.0) <B7573888-BAF6-333D-AB00-C0D2BF88DF0F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff871d1000 - 0x7fff874e3fff com.apple.Foundation (6.7 - 833.1) <618D7923-3519-3C53-9CBD-CF3C7130CB32> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff87729000 - 0x7fff87754ff7 libxslt.1.dylib (3.24.0 - compatibility 3.0.0) <8051A3FC-7385-3EA9-9634-78FC616C3E94> /usr/lib/libxslt.1.dylib
0x7fff87755000 - 0x7fff87755fff com.apple.vecLib (3.7 - vecLib 3.7) <29927F20-262F-379C-9108-68A6C69A03D0> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff87756000 - 0x7fff87757ff7 libremovefile.dylib (21.0.0 - compatibility 1.0.0) <C6C49FB7-1892-32E4-86B5-25AD165131AA> /usr/lib/system/libremovefile.dylib
0x7fff87758000 - 0x7fff8775ffff libCGXCoreImage.A.dylib (600.0.0 - compatibility 64.0.0) <40374018-2832-3144-8114-CED417321C76> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x7fff87760000 - 0x7fff87804fef com.apple.ink.framework (1.3.2 - 110) <F69DBD44-FEC8-3C14-8131-CC0245DBBD42> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff87805000 - 0x7fff87846fff com.apple.QD (3.12 - ???) <4F3C5629-97C7-3E55-AF3C-ACC524929DA2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8789c000 - 0x7fff8790afff com.apple.CoreSymbolication (2.1 - 66) <E1582596-4157-3535-BF1F-3BAE92A0B09F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff8790b000 - 0x7fff87928fff com.apple.frameworks.preferencepanes (15.0 - 15.0) <CC86755A-6CF1-3DDF-A1B0-6F7F5BD7BB39> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
0x7fff87929000 - 0x7fff879bbfff com.apple.PDFKit (2.6 - 2.6) <F838E95F-DEE9-354A-A34A-F5335D0AF1E1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x7fff879bc000 - 0x7fff87a40ff7 com.apple.ApplicationServices.ATS (5.0 - ???) <F10B1918-A06E-3ECF-85EF-05F0CF27187E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff87a72000 - 0x7fff87b74ff7 libxml2.2.dylib (10.3.0 - compatibility 10.0.0) <D46F371D-6422-31B7-BCE0-D80713069E0E> /usr/lib/libxml2.2.dylib
0x7fff87b75000 - 0x7fff87de3ff7 com.apple.QuartzComposer (5.0 - 232) <CE01B3AC-C19F-3148-9301-615E8FD6F356> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x7fff87e6b000 - 0x7fff87eaaff7 libGLImage.dylib (??? - ???) <29F82AD9-45F0-3AC5-A4A4-B767EC555D82> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x7fff87eab000 - 0x7fff881cefff com.apple.HIToolbox (1.7 - ???) <10FA3432-6638-39D9-8681-9E95298D239E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff881cf000 - 0x7fff88216ff7 com.apple.CoreMedia (1.0 - 705.35) <6BEC7E0A-BC2E-30DA-8E18-7AF6E8A7821F> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
0x7fff88217000 - 0x7fff8837afff com.apple.CFNetwork (520.0.13 - 520.0.13) <67E3BB43-2A22-3F5A-964E-391375B24CE0> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8837b000 - 0x7fff883cefff com.apple.AppleVAFramework (5.0.14 - 5.0.14) <5FA4AED9-8E55-389C-9F5B-02FFE5BCBB75> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x7fff883cf000 - 0x7fff88417fff com.apple.framework.CoreWLAN (2.0 - 200.46) <04AFD988-DDFB-330D-B042-C1EB2826A0CC> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff88453000 - 0x7fff88492ff7 libcups.2.dylib (2.9.0 - compatibility 2.0.0) <DE681910-3F7F-3502-9937-AB8008CD281A> /usr/lib/libcups.2.dylib
0x7fff88493000 - 0x7fff88654fe7 com.apple.CoreData (103 - 358.4) <8D8ABA2E-0161-334D-A7C9-79E5297E188B> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff8865b000 - 0x7fff88660ff7 libsystem_network.dylib (??? - ???) <4ABCEEF3-A3F9-3E06-9682-CE00F17138B7> /usr/lib/system/libsystem_network.dylib
0x7fff88661000 - 0x7fff88662fff libdnsinfo.dylib (395.6.0 - compatibility 1.0.0) <718A135F-6349-354A-85D5-430B128EFD57> /usr/lib/system/libdnsinfo.dylib
0x7fff88663000 - 0x7fff88676ff7 libCRFSuite.dylib (??? - ???) <034D4DAA-63F0-35E4-BCEF-338DD7A453DD> /usr/lib/libCRFSuite.dylib
0x7fff88682000 - 0x7fff886a1fff libresolv.9.dylib (46.0.0 - compatibility 1.0.0) <33263568-E6F3-359C-A4FA-66AD1300F7D4> /usr/lib/libresolv.9.dylib
0x7fff88879000 - 0x7fff88aeafff com.apple.CoreImage (7.77 - 1.0.1) <AB6ECCF3-4B04-3363-9158-08F305BF15FA> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff88aeb000 - 0x7fff88af1fff libGFXShared.dylib (??? - ???) <DE6987C5-81AC-3AE6-84F0-138C9636D412> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff88af2000 - 0x7fff88b07fff com.apple.speech.synthesis.framework (4.0.74 - 4.0.74) <C061ECBB-7061-3A43-8A18-90633F943295> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff88b08000 - 0x7fff88c92ff7 com.apple.QTKit (7.7.1 - 2246) <C8A57DE8-A86A-34B6-B6BA-565EE3B6D140> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x7fff88c93000 - 0x7fff88cf7fff com.apple.Symbolication (1.2 - 83.1) <0C6F8907-6829-3409-99AC-ACC62923DE98> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff88cf8000 - 0x7fff88dd5fef libsystem_c.dylib (763.11.0 - compatibility 1.0.0) <1D61CA57-3C6D-30F7-89CB-CC6F0787B1DC> /usr/lib/system/libsystem_c.dylib
0x7fff88e58000 - 0x7fff88eeeff7 libvMisc.dylib (325.3.0 - compatibility 1.0.0) <AC5A384A-FA5A-3307-9CED-BD69E6F12A09> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff88efb000 - 0x7fff88f4bfff com.apple.CoreMediaIO (201.0 - 3148) <66287EB0-61F1-3175-90DC-24BB29473C67> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
0x7fff88f4c000 - 0x7fff89048ff7 com.apple.avfoundation (2.0 - 180.23) <C4383696-561D-33F3-AD7C-51E672F580B2> /System/Library/Frameworks/AVFoundation.framework/Versions/A/AVFoundation
0x7fff89049000 - 0x7fff89464fff com.apple.SceneKit (2.0 - 124) <9E331DDE-BDF4-34C5-A8F9-E7F12ADBB785> /System/Library/PrivateFrameworks/SceneKit.framework/Versions/A/SceneKit
0x7fff89465000 - 0x7fff89492fff com.apple.quartzfilters (1.7.0 - 1.7.0) <ED846829-EBF1-3E2F-9EA6-D8743E5A4784> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x7fff896d1000 - 0x7fff898defff com.apple.JavaScriptCore (7534 - 7534.48) <99B60407-592A-3DDC-A3D0-86578B92B3F8> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff898df000 - 0x7fff89ec3faf libBLAS.dylib (??? - ???) <D62D6A48-5C7A-3ED6-875D-AA3C2C5BF791> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff89ec4000 - 0x7fff89f1efff com.apple.HIServices (1.9 - ???) <8791E8AA-C034-330D-B2BA-5141154C21CD> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff89f1f000 - 0x7fff89f33ff7 com.apple.LangAnalysis (1.7.0 - 1.7.0) <04C31EF0-912A-3004-A08F-CEC27030E0B2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff89f34000 - 0x7fff89fb9ff7 com.apple.Heimdal (2.1 - 2.0) <E4CD970F-8DE8-31E4-9FC0-BDC97EB924D5> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff89fba000 - 0x7fff8a0bdfff libsqlite3.dylib (9.6.0 - compatibility 9.0.0) <ED5E84C6-646D-3B70-81D6-7AF957BEB217> /usr/lib/libsqlite3.dylib
0x7fff8a0be000 - 0x7fff8a0cbfff libCSync.A.dylib (600.0.0 - compatibility 64.0.0) <931F40EB-CA75-3A90-AC97-4DB8E210BC76> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x7fff8a0cc000 - 0x7fff8a0dafff com.apple.NetAuth (1.0 - 3.0) <F384FFFD-70F6-3B1C-A886-F5B446E456E7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff8a5a3000 - 0x7fff8a5a7fff libdyld.dylib (195.5.0 - compatibility 1.0.0) <F1903B7A-D3FF-3390-909A-B24E09BAD1A5> /usr/lib/system/libdyld.dylib
0x7fff8a5a8000 - 0x7fff8a5afff7 com.apple.CommerceCore (1.0 - 17) <AA783B87-48D4-3CA6-8FF6-0316396022F4> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCore.framework/Versions/A/CommerceCore
0x7fff8ac14000 - 0x7fff8acc6fff com.apple.CoreText (4.0.0 - ???) <D7BD85FD-277A-3A97-B1AD-5EE14215237E> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x7fff8acc7000 - 0x7fff8ad0aff7 libRIP.A.dylib (600.0.0 - compatibility 64.0.0) <2B1571E1-8E87-364E-BC36-C9C9B5D3EAC4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff8ad0b000 - 0x7fff8b3d99df com.apple.CoreGraphics (1.600.0 - ???) <B3C42497-53F5-31BB-987E-D1E76746B0E4> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff8b3da000 - 0x7fff8b3ddfff libCoreVMClient.dylib (??? - ???) <9E9F7B24-567C-3102-909C-219CF2B191FD> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff8b3e7000 - 0x7fff8b404fff libPng.dylib (??? - ???) <75DA9F95-C2A1-3534-9F8B-14CFFDE2A290> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8b405000 - 0x7fff8b407fff libquarantine.dylib (36.0.0 - compatibility 1.0.0) <4C3BFBC7-E592-3939-B376-1C2E2D7C5389> /usr/lib/system/libquarantine.dylib
0x7fff8b408000 - 0x7fff8b49afff com.apple.CorePDF (3.0 - 3.0) <6056B710-155A-3543-9373-B9F3E5FC99CE> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
0x7fff8bbd4000 - 0x7fff8be4eff7 com.apple.imageKit (2.1 - 1.0) <03200568-184B-36E8-AFE9-04D1FACDC926> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x7fff8be4f000 - 0x7fff8be55ff7 libunwind.dylib (30.0.0 - compatibility 1.0.0) <1E9C6C8C-CBE8-3F4B-A5B5-E03E3AB53231> /usr/lib/system/libunwind.dylib
0x7fff8bea1000 - 0x7fff8bea2fff com.apple.MonitorPanelFramework (1.4.0 - 1.4.0) <0F55CD76-DB24-309B-BD12-62B00C1AAB9F> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x7fff8bea3000 - 0x7fff8bea3fff com.apple.quartzframework (1.5 - 1.5) <21FCC91F-C7B9-304F-8C9C-04F3924F4AE3> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x7fff8bea4000 - 0x7fff8beaaff7 com.apple.phonenumbers (1.0 - 47) <8CE13253-C65B-392F-B87F-D85A15D500D3> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
0x7fff8beab000 - 0x7fff8bf72ff7 com.apple.ColorSync (4.7.0 - 4.7.0) <A29897D7-4B63-3BBB-B66C-710BE9CC01D8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8bf7d000 - 0x7fff8bf7dfff com.apple.Carbon (153 - 153) <895C2BF2-1666-3A59-A669-311B1F4F368B> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x7fff8bf7e000 - 0x7fff8bf94ff7 com.apple.ImageCapture (7.0 - 7.0) <69E6E2E1-777E-332E-8BCF-4F0611517DD0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff8bf95000 - 0x7fff8c093ff7 com.apple.QuickLookUIFramework (3.0 - 489.1) <A8A82434-D43D-3F12-9321-B2E8EC9B4B8E> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x7fff8c094000 - 0x7fff8c0a1ff7 libbz2.1.0.dylib (1.0.5 - compatibility 1.0.0) <8EDE3492-D916-37B2-A066-3E0F054411FD> /usr/lib/libbz2.1.0.dylib
0x7fff8c0a2000 - 0x7fff8c112fff com.apple.datadetectorscore (3.0 - 179.3) <AFFBD606-91DE-3F91-8E38-C037D9FBFA8B> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8c113000 - 0x7fff8c1f3fff com.apple.CoreServices.OSServices (478.25.1 - 478.25.1) <E7FD4DB7-7844-355A-83D0-C1F24BE71019> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff8c1f4000 - 0x7fff8c1f4fff com.apple.CoreServices (53 - 53) <5946A0A6-393D-3087-86A0-4FFF6A305CC0> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8c1f5000 - 0x7fff8c2eafff libiconv.2.dylib (7.0.0 - compatibility 7.0.0) <5C40E880-0706-378F-B864-3C2BD922D926> /usr/lib/libiconv.2.dylib
0x7fff8c2eb000 - 0x7fff8c324fe7 libssl.0.9.8.dylib (0.9.8 - compatibility 0.9.8) <D634E4B6-672F-3F68-8B6F-C5028151A5B4> /usr/lib/libssl.0.9.8.dylib
0x7fff8c334000 - 0x7fff8c39bff7 com.apple.audio.CoreAudio (4.0.0 - 4.0.0) <0B715012-C8E8-386D-9C6C-90F72AE62A2F> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff8c42f000 - 0x7fff8c434fff libcache.dylib (47.0.0 - compatibility 1.0.0) <B7757E2E-5A7D-362E-AB71-785FE79E1527> /usr/lib/system/libcache.dylib
0x7fff8c47c000 - 0x7fff8c64fff7 com.apple.CoreFoundation (6.7 - 635) <57446B22-0778-3E07-9690-96AC705D57E8> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8c650000 - 0x7fff8d248fff com.apple.AppKit (6.7 - 1138) <C8D2FDDA-B9D5-3948-A376-6B9B6F0596C6> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8d249000 - 0x7fff8d2abff7 com.apple.coreui (0.3 - 162) <A752F9D0-1CAE-340F-B2D2-95EEF242B301> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff8d33e000 - 0x7fff8d397fff com.apple.Suggestions (1.0 - 84.0) <6B925EBB-CEEF-3134-8D25-2103F21DE624> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
0x7fff8d398000 - 0x7fff8d39dfff com.apple.OpenDirectory (10.7 - 144) <E8AACF47-C423-3DCE-98F6-A811612B1B46> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x7fff8d39e000 - 0x7fff8d3a3fff libpam.2.dylib (3.0.0 - compatibility 3.0.0) <D952F17B-200A-3A23-B9B2-7C1F7AC19189> /usr/lib/libpam.2.dylib
0x7fff8d456000 - 0x7fff8d483ff7 com.apple.opencl (1.50.62 - 1.50.62) <616ADE61-11D1-3816-A255-3F0F80F2EAC8> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8d484000 - 0x7fff8d492ff7 com.apple.AppleFSCompression (37 - 1.0) <88C436E8-38AE-3D96-A8C8-2D1805CC47B7> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompression
0x7fff8d4d3000 - 0x7fff8d525ff7 libGLU.dylib (??? - ???) <C3CE8BA0-470F-3BCE-B17C-A31E70E035F2> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
External Modification Summary:
Calls made by other processes targeting this process:
task_for_pid: 19
thread_create: 0
thread_set_state: 0
Calls made by this process:
task_for_pid: 0
thread_create: 0
thread_set_state: 0
Calls made by all processes on this machine:
task_for_pid: 258
thread_create: 0
thread_set_state: 0
VM Region Summary:
ReadOnly portion of Libraries: Total=205.7M resident=142.9M(69%) swapped_out_or_unallocated=62.8M(31%)
Writable regions: Total=646.7M written=466.1M(72%) resident=495.4M(77%) swapped_out=0K(0%) unallocated=151.3M(23%)
#347544
follow up of previous ( message size limit..)
REGION TYPE VIRTUAL
ATS (font support) 31.9M
CG backing stores 4404K
CG image 88K
CG raster data 128K
CG shared images 3416K
CoreGraphics 16K
CoreImage 8K
CoreServices 1564K
MALLOC 572.5M
MALLOC guard page 32K
MALLOC_LARGE (reserved) 5220K reserved VM address space (unallocated)
Memory tag=240 4K
Memory tag=242 12K
OpenCL 52K
STACK GUARD 56.1M
Stack 14.2M
VM_ALLOCATE 17.5M
__CI_BITMAP 80K
__DATA 20.3M
__IMAGE 1256K
__LINKEDIT 50.0M
__TEXT 155.7M
__UNICODE 544K
mapped file 38.5M
shared memory 11.4M
TOTAL 984.5M
TOTAL, minus reserved VM space 979.4M
Model: MacPro4,1, BootROM MP41.0081.B07, 8 processors, Quad-Core Intel Xeon, 2.26 GHz, 16 GB, SMC 1.39f5
Graphics: NVIDIA GeForce GT 120, NVIDIA GeForce GT 120, PCIe, 512 MB
Memory Module: DIMM 1, 2 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x31384A53463235363732415A2D3147314431
Memory Module: DIMM 2, 2 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x31384A53463235363732415A2D3147314431
Memory Module: DIMM 3, 2 GB, DDR3 ECC, 1066 MHz, 0x80CE, 0x463732353655363146373036364700000000
Memory Module: DIMM 4, 2 GB, DDR3 ECC, 1066 MHz, 0x80CE, 0x463732353655363146373036364700000000
Memory Module: DIMM 5, 2 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x31384A53463235363732415A2D3147314431
Memory Module: DIMM 6, 2 GB, DDR3 ECC, 1066 MHz, 0x802C, 0x31384A53463235363732415A2D3147314431
Memory Module: DIMM 7, 2 GB, DDR3 ECC, 1066 MHz, 0x80CE, 0x463732353655363146373036364700000000
Memory Module: DIMM 8, 2 GB, DDR3 ECC, 1066 MHz, 0x80CE, 0x463732353655363146373036364700000000
Bluetooth: Version 2.5.0f17, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet 1, Ethernet, en0
PCI Card: NVIDIA GeForce GT 120, sppci_displaycontroller, Slot-1
Serial ATA Device: HL-DT-ST DVD-RW GH41N
Serial ATA Device: WDC WD6400AAKS-41H2B0, 640,14 GB
Serial ATA Device: WDC WD5000AADS-00S9B0, 500,11 GB
USB Device: hub_device, apple_vendor_id, 0x9136, 0xfa200000 / 2
USB Device: hub_device, apple_vendor_id, 0x9137, 0xfa240000 / 3
USB Device: Display Audio, apple_vendor_id, 0x2912, 0xfa241000 / 6
USB Device: Apple LED Cinema Display, apple_vendor_id, 0x9236, 0xfa243000 / 5
USB Device: Display iSight, apple_vendor_id, 0x8508, 0xfa242000 / 4
USB Device: Keyboard Hub, apple_vendor_id, 0x1006, 0xfd100000 / 2
USB Device: Apple Optical USB Mouse, apple_vendor_id, 0x0304, 0xfd130000 / 4
USB Device: Apple Keyboard, apple_vendor_id, 0x0221, 0xfd120000 / 3
USB Device: BRCM2046 Hub, 0x0a5c (Broadcom Corp.), 0x4500, 0x5a100000 / 2
USB Device: Bluetooth USB Host Controller, apple_vendor_id, 0x8215, 0x5a110000 / 5
FireWire Device: built-in_hub, 800mbit_speed
#347546
Given the next point, the plugin is not preventing this workflow, correct?
As mentioned above, it works in Default mode, and this eliminates the first problem, correct? Unfortunately, I have never reproduced this problem here, so I am still not sure what causes it; that is the only reason why using Custom browsers is optional.
Thanks, but I don't write MXED, so I can't help you much with it. I'd recommend reporting this in the OSX forum, and indicating which version of MXED you are using.
