- Fri Aug 05, 2011 11:17 am
#345868
Hello there,
I'm modelling a small bathroom (modernization) interior for a customer with Sketchup.
The top of the washstand is made by a face, facing upwards with a simple white plastic material (225,225,225).
On top of it (with a distance of 0,2 mm), there is a 'solid' (i.e. a panel with a thickness of about 1 cm) with a simple glass material, made with the wizard.
The aim is to simulate a glass plate with a white coating on the bottom
The scenery is illuminated by 7 IES (downlights).
The problem is:
The glass plate seems to be to dark. It is not reflecting white, but grey. The small glass plates of the small shelf above the washstand are also too dark in my judgement.
It is not possible to increase the power of the downlights enough to lighten the glass without overexposing the scenery.
The only thing I found is this:
I can make the ceiling of the bathroom (which is white) invisible an turn on sky dome in addition to the IES downlights. But this is not the target since I wanted to show the bathroom with only the downlights turned on.
Do you have any ideas?
Thank's a lot.
Umdrehung
The problem is:
Thank's a lot.
Umdrehung
Mac OS X 10.11.6
Sketchup plugin 3.1
Maxwell 3.2.5
Sketchup plugin 3.1
Maxwell 3.2.5
- By Mark Bell
- By Mike Amos 20251018183343
