By Pistol
#345321
Hi All,
Does anybody know where the Benchwell.com site has been moved too? And/or where I could download the sculpture.mxs scene?
Thanks
By Pistol
#345324
Thanks Herve'
My French isn't that good, is there an English version anywhere?
By numerobis
#349840
Thanks! This is much better :D
But it would be good if you could clean up the list from faulty entries like this one:
Intel i7 - 2600, 4, 04:47, 1446, 3.4, 8, allienware, SEVEN 64, Matt
4:47 is simply not possible with an i7 2600 @ stock speed - it should be around 8 min (if you compare it to the other 2600@3,4 in your list)
or these
X5675, 12, 04:18, 2478, 3.07, 12, SEVEN 64, le13emepanda
i7 2600k, 4, 05:23, 1282, 3.50, 16, P8P67 Pro, SEVEN 64, Sensor
intel xeon E5530 x16cores, 12, 06:17, 1539, 2.40, 12, HP ProLiant Dl370, SEVEN 64, Alex
i7 920, 4, 07:13, 0000, 2.66, 24, Asus P6T V2 Deluxe, SEVEN 64, kardo
i7 920, 4, 07:13, 0959, 2.66, 24, Asus P6T V2 Deluxe, SEVEN 64, kardo
and maybe a standart naming not things like this:
bi-hexa X5670
there are eight different definitions for the same thing:
bi-hexa X5670
Dual Xeon X5670
DUAL 5650
2x Xeon X5680
X5675
xeon
Xeon ( 2009 )
By dec13els_fr
#349886
Thanks for your help numerobis,
I have a problem with the name of cpu.. there is too long list of processor to enter in db
Perhaps by cutting the form with the choice between Intel and AMD, choose between single and dual cpu
I am unfortunately not developers as I do this for my mind off ^ ^
By numerobis
#349891
i think it's very important to have the correct CPU name and specs in the list, otherwise this list is pretty useless.
I don't know how the data input works, but if you don't have a complete database and anyone has to type in the cpu name then you could say them to search the name in a list like this one:
http://www.techpowerup.com/cpudb/
(or you could copy this list into you database ;) )
