- Thu Jun 09, 2011 12:32 am
#343558
hi,
I m using Maya 2010, the latest Maxwell plugin, on OSX.
I've noticed several difference between the preview and the render output that makes the camera layout process a little bit cumbersome.
- Maya default film aspect ration is 1.5 when maxwell is 1.0 so you always have to rectify this manually or you're good to do your layout again.
- MaxwellFire uses the fit resolution gate "fill" when maxwell real output uses "vertical".
is there a way to make it as default that maya, maxwellFire, et maxwell output be the same ?
thank you
thank you
- By jack marvia
- By Mark Bell
