By Primus
#343200
Hi all
I played a bit with the animation of the light values in the multilight window. I animated some of the light emitters, changed the intensity values. Everything works fine, but the animation is only played in the small preview window.
It´s possible to see the animation in the camera window ?
Best,
Thomas
By Half Life
#343210
You can see any individual frame of the animation in the main window by going to the frame and hitting refresh... but to see the full animation you would need to export the files.
The reason for this is each frame takes some additional time to output/render the changes.
Best,
Jason.
By Primus
#343211
Thank you , Jason , i understand.
