By dubir
#343052
Dera all
please advise what is the best way to put general light on a model .
i design exhibition stands and want to use general light to illuminate my model this light will be additional to the other lights .
By brodie_geers
#343058
You've basically got 3 options, sun, skydome, and HDRI. Sun would be silly. Skydome will give you a nice even light. HDRI has the ability to give you a more realistic look if that's your schtick.
-Brodie
By dubir
#343089
yes i try the sky dome but
i dont want the bacground to be change.
in other word i want the background stay white , and just control the amount of illumination without changing the color of the bacground .
By brodie_geers
#343090
Go to your Environment parameters. Set your skydome how you want it and then switch to IBL. Check "Disabled" for Illumination and change the "Use for Disabled" dropdown from the default Physical Sky to Skydome. Then place an pure white .hdr map in you Background slot.
-Brodie
By dubir
#343255
Dear all
I try it
But when i change the amount (with the slide) of the sky dome the background change from withe to gray and i want it to be white all the time
