-  Mon May 16, 2011 3:22 am
					 #342713
							Hi folks,
I wondered if there is a formula or approximation which one use to predict the render time for a larger resolution.
Yes, I know that the render time depends entirely on the scene as so the number of SL to go.
I usually render out my drafts in 720x405 @ SL12. Lets say I am satisfied with the result of one of my preview and want to render out in a higher resolution 1920x1080 or even higher at the same SL level. Is there any math one can do to predict the render time?
Regards.
Regards.
 . These are at 5000-6000 pixels maximum length meant for arch-viz prints. Depending on lighting conditions I will more or less know what is going to need more samples, keep testing and you will quickly get a good indication of what you will need in the future.
 - By Mark Bell
 - By Mark Bell - By Mike Amos 20251018183343
 - By Mike Amos 20251018183343 - By Blanchett
 - By Blanchett
