#341715
Hello,
The plugin code of the new (modo 501) plugin version is 99% ready. It is compatible with with modo 501 win32/64 bit and OSX 32/64 bit.
We are currently waiting for more feedback from our beta tester team to be sure if it is stable and good enough to release.
Márton
#341988
Marton Day8 wrote:Hello,
Márton
How is the Beta Testing coming along?
As a recent Maxwell Licensee, it is 'burning a hole' on my iMac waiting to be used (My latest scene is 501 which doesn't open in 401 so having both versions isn't really an option/or want). I have tried exporting from 501 and importing into Studio but every model is a mess. I have tried freezing the meshes and triangulating which helps a bit, but I have a large Arch Viz scene I'm just gagging to render in Maxwell. Until the plugin is released, does anyone have a good workflow for rendering using Maxwell Studio?
A rough-ETA for 501 plugin release?
Best Regards,
Matt.
#343464
Ehm... :-(
Fire doesn't seem to work.
I get always a crash when I "fire" it.
I'm on Win Xp 32 bit and SP3.
Testing more...
Regards, Gio
P.S. Confermed, even with a fresh restart.
Exported model in Studio (and Fire) works fine.
I'll test tonight on Win 7 64bit at home.
#343467
I afraid to say that this isn't altogether working well for me.
1. After install I am not seeing the Preferences in the menu, and it is also blank in the plugin pane.
2. I am also not getting any properties when I select a Material or Object etc within the plugin window.
3. When I select Render, the modo baking window pops up and modo crashes.
hmmm... I have tried deleting the plugin from the Application Support/Luxology/Plugins and re-installing, but I am getting the same issues. Is there anywhere else that files may be living which I haven't deleted before the fresh install??
Regards,
Matt.
Mac OSX, Cocoa Modo 501 Install SP3
#343468
Thanks for the nice and big update of the plugin, it looks great!
Correction to my previous post.. i HAD a problem with crashes and it appears to be that i made a mistake and had both x32 and x64 selected when i installed it, reinstalling the plugin with only x64 selected eliminated the crashes.
/ Magnus
