I just noticed tonight that in studio the time of render is measured in minutes whereas a queued network render it is measured in hours. Therefore if my scene is set for 60 minutes in studio, queuing in network render recognizes it as 60hrs. Is there a specific reason for this or is it a setting I'm missing?
#340812
Anybody from NL able to chime in? Having the input like this means the minimum render time you can do is one hr (if you're basing your renders on time and not SL). Seems odd to have the inconsistency between programs. Also, let's say you ahve 10 different scenes you want to batch render. You've been test rendering out of studio, so once you go to do a batch render this means you would have to manually open up all 10 scenes to convert the render time from minutes to hrs.
