Here's a quick render of some modifications I made to your Maxwell file in Studio -- mostly I adjusted exposure and materials related settings. Hopefully this is a bit closer to what you were shooting for lighting/exposure wise.
http://www.spotoarts.com/jason/kitchen/ ... ersion.zip
I have no idea why you need such strong emitters -- I checked your scale and everything is properly scaled... it could be an emitter geometry issue but I didn't check that.
Best,
Jason.
#337143
actually you can tweak nearly everything when using multilight...
try vignetting strentgh and burn value... by lowering the burn value you can get more light into the room withouth literally burning the window and near objects...
cheers
#337253
To be fair your materials design and choices don't allow for alot of contrast -- but this is problem that can be easily fixed in post (in Photoshop or similar).
If you want to get better contrast, and generally more interesting raw renders from Maxwell you should do some work on your materials... for more information you can watch some of my videos free on the Maxwell THINK! site: http://think.maxwellrender.com/first10s ... egoryFS=21
Best,
Jason.
