- Mon Jan 31, 2011 6:10 pm
#336975
Good morning friends,
Thanks to all of you for your answers this weekend. As we are novices to Maxwell, your patience is appreciated. Some questions about the Rendering output end of the process:
1) If we will want to print out a rendering for presentation to a client, we understand that it is best to set the Color Space to Adobe RGB 98 (right?). To determine the resolution, we would set the Type on Manual and enter the desired output in the Output(w/h) fields. Now, to determine this we printed out a Photo Printing Resolutions table off the internet. It says, for example, that to print out an image tht is 15" wide x 10" high you should set your pixels at 4,536 x 3,024 (at 300 ppi). Our questions are:
a) Is there a limit to how big you an make the output? For example, can you enter 10,000 x 8,000 if we had a printer big enough to print larger prints?
b) Does it take longer (in time) to render an image that is larger? (This may seem obvious, but still want to ask.)
2) If we want to create a rendering that will just be viewed on the computer screen, we understand that we should set the color space to sRGB (right?) and we want the image to be as big as possible -- for example, we have a 27" monitor and would like the image to fill the screen when we choose Full View -- what resolution should we choose? Viewing an image on a screen should be 72 ppi (right?) therefore, it would take less resolution (fewer pixels) to generate a bigger image. Our question is --
a) How do we determine how many pixels we want to make it if we want the image of the render to fill the screen?
b) Once we do this if we choose Full Screen in the View pull-down menu then we won't see any black around the image right?
3) Once a rendering is completed, is it possible to restart it and "raise the bar higher" by raising the SL and/or time. Can you resume a rendering after it has been completed? Even if you've closed the file, quit Maxwell etc. To do this do you choose File/ Open MXI or MXS in the Core Application and what's the difference?
Thank you, all. We really appreciate the guidance.
Cosmas Demetriou
Cosmas Demetriou
