#336925
With the latest MazwellZ plugin 2.0.4.0 vs 2.0.3.3 WIN 32BIT I am noticing that with the same model some elements are dissappearing when rendered directly from fz with the 2.0.4.0 plugin. did a geometry check and the element was well formed...and tried the Maxwell checkoff for fixing geometry but that does not change the result. Has anyone else seen this happen. I went back to 2.0.3.3 and the geometry rendered fine.
thanks
