By messire
#331910
Hi all,
We're facing a problem with sun positionning ( SU7 and 2.1.12 plugin )
We cannot get a correct sun position in the render...any clue?
We're having the sun come from left in sketchup, but comes from far right ( behind building) in MR...
Here are the two images of the render :
thnx for hints, finally found some time to install for real the last plug in !! cant wait to try out with better results...
Nils
#331911
Could you email (jeremy at nextlimit dot com) a simple SketchUp file that reproduces this? For what it's worth, the angle is taken directly from SketchUp.
By messire
#331926
thnx JD,
I think i solved the issue by resetting all the environnement settings in the Maxwell window inside sketchup ( the dot at the end of each line)...it now works, i still wonder how it went into those settings, and especially why the sun moved around 180° when there is no settings for that!...anyway it works now!
Nils
