By sam7
#329548
Well if we had the time/budget here I'd get a wood panel and take photos from all different viewing & light angles myself, and see what I can make of it... but though, surely someone has already done that somewhere....
By sam7
#329551
Cool I found some of the files and the shader coder they've used:
http://www.cs.cornell.edu/~srm/publicat ... d-data.tgz
This is the most interesting map: Image
Description in the shader for this map:
containing 3-channel texture modulating fiberAxis across the patch. Values are mapped [0:max] -> [-1:1] for each component, since most image file formats are unsigned.
I wonder what would happen if one would convert this from a vector3 into a anisotripc map. Any idea how to add the colour channels in photoshop to get a good result?
