- Sun Aug 22, 2010 5:03 pm
#329284
Yes. Use the network render system so that it will save incremental mxi updates to a local temp folder instead of writing each update to the network drive. Then, only the final output will be written to the network drive when the render has been stopped. Even if you are only using one computer running node, monitor and manager it works this way.
Brian Looney
Maxwell + RealFlow
