By osuire
#328605
When "faking" a projected view by setting a huge lens length, I get this "zommed out" effect in the render...
As you can see, in the viewport, the framing is fine.
I used to do this all the time, and now it craps on me suddenly...
http://www.box.net/shared/static/z91cnc9yvs.jpg
What am I doing wrong ?
Will there be a more elegant way to do those projected views in the future ?
Cheers,
Olivier
#328610
It seems that this was due to the value I chose for lens length : 100 000mm
Setting it to just 10 000mm made the trick work again.
Would it hurt Next Limit's unbiased feelings if it was possible to render a parallel view without any workarounds ?
Olivier
#328617
Newer SDKs (Maxwell) have some functions designed to help me emulate Studio's 'fake parallel' views, but I have not begun to try to integrate them yet, since I basically have to rewrite the whole camera-handling part of the plugin, due to V5's new two-point projection modes.
On the question of having actual parallel projection cameras in Maxwell, you're really asking the wrong guy. :)
