- Wed Aug 04, 2010 9:56 pm
#328183
Hello,
sorry but I do not know if I am encouraged to use one of the two existing topics for the new plugin. Therefore I post this new one.
I've been testing the new Sketchup plugin for some days.
Thank you for the great work. It seems to be a great leap forward.
However maybe you can help with the following problems:
1. When I activate the mxm mode of the plugin and try to open an mxm file in the library nearly all mxm files are greyed out. Only new mxms that I generated freshly in Studio can be chosen. I checked the file extensions of the mxm file, but they are correct.
2. Every time I use the icons 'Render' or 'Export to Studio' I get the following error message:
'Unable to locate the Maxwell MXS exporter, Skp2Mxs.plugin, which is expected to be located in the standard SketchUp Exporters folder.
Error info: Located SketchUp, but the /PlugIns folder was not found'
I use Sketchup 7.1 with Mac OS X, with standard file locations and checked all parts of the plugin. Everything is just like it should be. The Skp2Mxs.plugin is located in the standard Export folder inside the Sketchup package.
Lastly a question on how to fix texture paths in Studio.
I tried to fix them using mxm-Checker or directly with 'Fix Texture Paths' of 'Studio' but nothing works reliable. Any Tips? mxm-Checker often quits with the message 'An exception of class NilObjectException was not handled' and Studio simply doesn't fix the texture paths.
Thank you for help,
umdrehung
Thank you for help,
umdrehung
Mac OS X 10.11.6
Sketchup plugin 3.1
Maxwell 3.2.5
Sketchup plugin 3.1
Maxwell 3.2.5
