- Fri Jul 16, 2010 8:46 pm
#326618
I have been having to use IBL lighting studios recently because I have some white semi translucent sss objects on my model. See attached previews for what I am talking about. The only way I have found them to clear and look correct is to use IBL to light my scene. The problem I keep having with these is that the lighting is very dull and has no contrast compared to standard emitters. Everything comes out very flat looking. Almost as if I was only using skydome. I would show the images I am getting, but they are under nda at the moment.
Has anyone else had any luck with studio hdr ligthing where the contrast is similar to using standard emitters? Here is a link to the free studio hdri if anyone wants to try them out. At first I thought maybe it was the size of the emitters in the hdr causing everything to be flat, but I am not sure how to scale it down. In the viewport the hdr is huge around my object. I have only used #18 and #19 so far. Maybe I should try something like #1 that has smaller emitters to see if that helps?
Quick image of the HDRi's:
http://img80.imageshack.us/img80/552/studioimages.jpg
HDRi Pack1: http://zbyg.deviantart.com/art/HDRi-Pack-1-97402522
HDRi Pack2: http://zbyg.deviantart.com/art/HDRi-Pack-2-103458406
HDRi Pack3: http://zbyg.deviantart.com/art/HDRi-Pack-3-112847728
- By jack marvia
