By Jesper Pedersen - Thu Jun 24, 2010 12:19 am
#325531
I am trying to send an animation sequence to render from 3ds max and i need the MXI intensity to be set to 3. For high res still images I can easily do this (when the maxwell window opens to run the render, I just type in 3 instead of the default 1) but obviously this is not practical when I have several hundred frames to render.
Is there a way of settingthis value within 3ds max before sending the render job or is there a way to change teh default value tothe required value?
- By jack marvia
