By RobMitchell - Mon Jun 21, 2010 3:25 pm
#325392
Hey. It's thankfully been a while since I've needed to post in here, but one thing that's popped up a few times is the fact I can't see materials applied to objects that have been patterned or mirrored in SolidWorks, and I was wondering if there was a way to remedy this. It can make things difficult when trying to get an overview of a scene and seeing what still needs materials or not. Here's a screenshot of what I mean...
As you can see, the grid (window frame) has had a green material applied to it which shows up fine. The two and a bit window frames directly to the right - which are seperate bodies but generated by using the linear pattern feature - have also had the same material applied but you can't see it. If I select the objects in the list the materials are applied and when I hit render they do show up (I believe). They're just not showing in SolidWorks... Is there any way to have them appear?
I'm using SolidWorks 2008 with the Maxwell 1.7 plugin on Windows XP 64-bit OS.
Any help would be great. Thanks.
- By Matteo Villa
