By mojo
#324408
as soon as i want to export my symbols as instances, maxwell crashes.
the project and the symbol library are saved on my server
i have maxwell 2.0.3 and
maxwellz v2.0.1.3 (b20)
win7 64 bit
formz 6.6.2
now i tried only maxwell materials in my symbols: the following error appears:
ERROR: - Instances of emitters are not supported.
ERROR: - Data preprocess failed. Render cannot continue
ERROR: - Render Failed "
with maxwell 2.0.2 it was working fine with my symbols.
unfortunately i cant find this version to download.
and i didnt save it on my computer.
is there a possibility to get the version 2.0.2 ??
By numerobis
#324409
i experienced the same situation exporting with instances from 3dsmax and sketchup (maxwell 2.0.3)
maxwell starts after export and crashes immediately... without instances everything works fine. :(
By pylon
#324460
Hi Mojo,
Yes, I am reproducing this, and this feature does indeed work properly with Maxwell 2.0.2. I will make some inquiries...
For, now, disabling the option to create Maxwell instances from formZ symbols in Maxwell Render Options > Export will work around the problem in Maxwell 2.0.3.
Best,
Ben
By Asmithey
#324547
I am crashing with instances too. This is actually a huge issue for me. i use lots of symbols and it takes way to long to export them when not instancing. Any Idea when this feature will be fixed? I have to go back to 1.7.1.
By pylon
#324817
It has been confirmed that this is a bug with Maxwell 2.0.3, and that it will be fixed with the next Maxwell Render release.
Until then, here are several workarounds:
-Temporarily revert to Maxwell Render 2.0.2
or
- Disable the option to create Maxwell instances from formZ symbols in Maxwell Render Options > Export
or
- only use symbols that have a single surface style/material in them (multiple materials in the symbol is the root of the problem)
or
- export your file in the normal fashion to Studio, rather than Maxwell, then render from Studio. This works for me; let us know if it works for you as well
Ben
By Asmithey
#325090
I tried exprting the file to Studio with export as instances checked. When I luanched the rendering from studio, Maxwell Render still crashes.
