By Jakob Ryngen
#324020
Hello,
My colleagues always complain about the white haze in the pictures rendered with Maxwell. I don't know if this is a feature, if I do something wrong or if this will go away with enough render time (like more than 100 hours in some cases). The problem is less so in close up renderings with less pixels - is this the problem? How do I control the amount of "white haze"?
Thanks,
By macray
#324022
the problem is the Scattering. But normally this issue was adressed in the last update and should not be there any more. Otherwise - just switch the scattering off or turn it to 0 when rendering...
