By Soth3d
#323758
I am trying to import materials into surface Shader and it always crashes. 64 bit LW, both HC 2012 and 9.6. :(
I am copying materials manually (layer by layer) from MMaterialEditor, but is so time consuming. :(
By Soth3d
#323766
Mihnea Balta wrote:How are you importing them? Are you importing MXM files with the button under the material tree?
Yap, I am clicking Import, it asks for a texture, I am choosing right one then crash.
By Mihnea Balta
#323770
Are you running the latest plug-in? There used to be a crash like you're describing in an earlier version, but it should be fixed in 2.0.16 (actually earlier, but I can't recall the exact release). If it still crashes with 2.0.16, could you send me the MXM you're trying to import?
By Mihnea Balta
#323774
The version is displayed when you click on the "Plugin Options" button (which calls the "MaxwellPluginOptions" command, in case you don't have it on your UI). Can I have that MXM file?
By Soth3d
#323776
I have latest one. I am at client office all day, I got bot files from on-line library, its wood_BUBINGA and wood6, I store them in Images folder of content directory (on network mapped drive).
If you will have problems finding it I will upload it tonight.
