By brodie_geers
#323058
I noticed some options in the material editor that I hadn't noticed before. Namely that you can create a "swatch" from your current settings and store it, then go back to those settings later. But I'm not sure that it's working.
I can save a swatch but if I then change the settings and click on the icon for that swatch nothing happens. Here's what it says in the manual.
• Previews: This drop down will list all the saved material swatches. Each swatch will
have a small preview and you can select it from the list to revert the material settings
to that swatch
. Alternatively, you can use the Browse swatch button at the bottom of
the Preview section.
• Store: Store the current material settings as a swatch. The saved swatch will save
all settings from the entire material, including if a texture is activated or not, texture
tiling, etc. Please note that these swatches are saved temporarily and will not be
available when you re-open the scene.
• Remove: Remove the currently selected
As I say, clicking the swatch does nothing. And I'm not sure what "Browse swatch" button is being referred to either. Is this a bug or is it just me?
-Brodie
