By Oli4D
#321656
Hello
I have a scene with some Xrefs (trees) and Maxwell Instances of that.
Since 2.0.3, that does not work anymore!
The client crashes or tells me that there are instances of emiters... wich is not true of course, there are no emitters in the instances (or the Xrefs the instances use).
In 2.0.2, that was working fine.
Not with 2.0.3, it's broken! :(
When can we expect a fix?
Thanks a lot,
Oliver
#321661
This is not a plugin issue -- I have reported problems in 2.0.3 regarding instances vs. multi-materials, and instances of objects which have no material. So, the options are to use a workaround: make sure the objects you are instancing have a material on them, and that they don't use multi-materials; otherwise, temporarily roll back to 2.0.2.
By Oli4D
#321662
JDHill wrote:This is not a plugin issue -- I have reported problems in 2.0.3 regarding instances vs. multi-materials, and instances of objects which have no material. So, the options are to use a workaround: make sure the objects you are instancing have a material on them, and that they don't use multi-materials; otherwise, temporarily roll back to 2.0.2.
All right, rolling back probably will be the fasted solution at the moment :(
Thanks Jeremy, hope they can fix this soon. Without implementing new bugs :D
