By bbyrtaylor - Mon Mar 29, 2010 11:00 am
#321229
I tried pretty much everything I can think of but I can't eliminate the following warning.
[LOG] *****************************************************************************************************
--- [FRAME 0] ---
[Warning]: Exporter can't convert modo environment image map to Maxwell IBL environment perfectly!
[Reason(s)]:
- Texture locator projection axis is not parallel with modo UP axis.
Please check Plugin Manual for further information about environment conversion!
As far as I can see all the setting is OK but I kept getting this warning. Can you help me please.
******Never mind I fixed the problem I had to reduce the scale down to 1X 1Y and 1Z that's strange I tried making it larger but not smaller before I fixed it.******
God Bless
--- [FRAME 0] ---
[Reason(s)]:
God Bless
Bobby R Taylor
- By Mark Bell
