- Mon Mar 15, 2010 7:22 am
#320398
From the video -
The Unlimited Detail engine works out which direction the camera is facing and then searches the data to find only the points it needs to put on the screen it doesnt touch any unneeded points, all it wants is 1024*768 (if that is our resolution) points, one for each pixel of the screen. It has a few tricky things to work out, like: what objects are closest to the camera, what objects cover each other, how big should an object be as it gets further back. But all of this is done by a new sort of method that we call MASS CONNECTED PROCESSING. Mass connected processing is where we have a way of processing masses of data at the same time and then applying the small changes to each part at the end.
The result is a perfect pure bug free 3D engine that gives Unlimited Geometry running super fast, and it's all done in software.
http://www.youtube.com/watch?v=Q-ATtrImCx4&ttl=1
- By Mark Bell
