#319852
I seem to be unable to set a Textures Folder path by browsing to it by using the [...] button when in the Options-->Textures Folder(#). It appears that you can enter a path manually, but you can't browse to a folder. Perhaps there is an additional click or some thing else I'm not doing?
Ken
#319853
It's apparently due to some obscure issue that only shows up when the Microsoft .NET-based plugin is hosted in the SolidWorks UI. If you click the Scene Manager item in the main menu's Maxwell menu (or the Scene Manager toolbar button, if you have the Maxwell toolbar open), the Scene Manager will be removed from the Task Pane and shown in its own window -- the button should work then.
